I have a 10 digit random number and want to check if it’s dividable by 9 (other restrictions are upper three digits cannot consecutive in increasing order (0-1-2, 8-9-0 both not ok)).I’m thinking declare a packed array, and use constraint as {array} >>} % 9 != 0 to do. But don’t know how to declare a packed integer array.
In reply to aaaaaa:
What do you mean by a digit? Do you mean an array of 4-bit binary coded decimal digits?
Show some example values.
In reply to aaaaaa:
Are those decimal digits or hexadecimal digits?
In reply to aaaaaa:
module abc;
//option-1 : if you want to check the 10-digit integer value is multiple of 9
int array = 0123456789;
$display(array % 9);
//option-2 : if you want to check multiple of 9, reducing one digit every time
array = 0123456789;
while(array != 0)begin
$display(array, array % 9 );
array = array/10;
//option-3 : if you want to check the multiple of 9, for each of the digit in 10-digit value
array = 0123456789;
$display(array, (array%10) % 9);
array = array/10;
may be you are looking for one of the these three options?
In reply to yourcheers:
Since this seems to be an interview question that you both have failed, let me ask a few questions as hints.
- How many binary bits do you need to store a 10-digit decimal number
- How do you convert a binary number to decimal digits?
Hi. I think I may declare the question more in details. Since there are more restrictions. For example, the upper three digits cannot be consecutive. That’s why I think I need to choose array.
In reply to aaaaaa:
module abc;
array = 0123456789;
array = array/10;
array = 0123456789;
array = array/10;
min 30, max 34
multiply each binary digit with base & sum.
class A;
rand bit [33:0] number; // minimum 34 bits needed to hold 10 decimal digits
rand bit [3:0] digits[9:0];
constraint n {
number % 9 == 0; // must be divisible by 9
number < 34'd1_0000000000; // decimal range
foreach(digits[i]) // binary coded decimal BCD conversion
digits[i] < 10;
digits.sum(digit) with (digit * 34'd10**digit.index) == number;
A a=new;
initial repeat (10) begin
assert(a.randomize());
$display("%10d %0p", a.number, a.digits);
Hi Dave
can you please elaborate more
digits.sum(digit) with (digit * 34’d10**digit.index) == number;
This expression converts a series of decimal digits into its binary representation. You need to manually unroll the some reduction method and see the equation it generates.
