How can i write my payload data (sufficient bits) in buffer based on payload length from AHB.?
i need to write proper data in my buffer.
it means payload_length is F0 = 128 bits. this 128 bits i need to write on buffer from AHB driver.
the max payload_length is FF = 2048 bits.
so how can i write that random bits properly on buffer.
//in sequence_item
randc bit [15:0] payload_length; //first 8 bits are my payload_length [15:8]
//constraints
constraint burst_len_c{
                     (m_hburst == SINGLE) -> (burst_len==1);
                    (m_hburst inside {WRAP4,INCR4}) -> (burst_len==4);
     	             (m_hburst inside {WRAP8,INCR8}) -> (burst_len==8);
                     (m_hburst inside {WRAP16,INCR16}) -> (burst_len==16);
     	            }  //burst_len for ahb_driver
constraint size_c{
	             (m_hsize==WORD);
      	          }//my data bus support 32 bit only
in seq file
task body();
	   //write tx buffer
        `uvm_do_with(req,{req.m_hwrite == 1;req.m_haddr == 16'h4000;req.m_hburst == SINGLE;})
how can i make exact constraint based on payload_length and burst_length.?
the below piece of code for driver
virtual task drive_data(ahb_pkt req);
		addr_phase(req);
		for(int i = 0; i < req.burst_len-1; i++)
		    		addr_phase(req);
		    		data_phase(req);
		    	join
In reply to Rao.Bee:
What kind of constraints are you talking about ??
