How can I use hex value into enum?
In reply to yourcheers:
$size(colors) gives you the number of array elements, 8, which is the same as $bits(Colors) in this case. Colors.num gives the number of enumerations.
You could also use a do-while loop
module enum_datatype;
typedef enum bit[7:0] { red=8'h2, green, blue=8'h4, yellow, white=8'h10, black } Colors;
Colors Color;
//display members of Colors
Color = Color.first;
do begin
$display("Colors :: Value of  %0s \t is = %0d and Size is %d",Color.name,Color, $bits(Color));
Color = Color.next;
end while(Color != Color.first);
Sir,
Is there a way to use same enumeration value?
because I’d like to add to enum as
typedef enum reg[7:0] { a=10, b=10, c=10} like this one.
I encounters an error message as each enumeration constance must have a unique value.
What am I supposed to do?
