How can i monitor if the assertion never ran in the testcase so that my testcase can fail
So I have written a property as shown below my question is how can I make my test fail if the assertion never started its ideal because I am trying to avoid the false pass, any suggestions?
module csr_sva(
input clk,clr,val;
bit sva_csr_en = 1;
property p_clear_reg_after_signal;
@(posedge clk) disable iff(~sva_csr_en)
$rose(clr) |-> ##1 (val == 0);
assert_p_clear_reg : assert property(p_clear_reg_after_signal) $display(PASS); else `uvm_error(get_type_name, "FAIL");
class csr_hrd_self_clr extends base_test;
virtual task main_phase(uvm_phase phase);
write.reg
read.reg
In reply to Piyu:
To dynamically monitor if an assertion is ever triggered you can use the action block to modify variables, as shown below.
int pass, fail;
assert_p_clear_reg : assert property(p_clear_reg_after_signal) pass=pass+1;
 else begin
   fail=fail+1;
  end;
class csr_hrd_self
I believe that there might be some tool-dependent APIs to get statistics about the assertion results.
Ben@systemverilog.us
or Cohen_Links_to_papers_books - Google Docs
