How can i implement fork-join() functionality without using the fork join construct in system verilog
This question was asked during an interview. Can you help me with question. I tried putting the threads in two different initial blocks but couldn’t get the required result.
this is a sample of the code i tried:
module tb();
initial
process(a);
initial
process(b);
The above can lead to a race condtion and will not get the desired result. Can you suggest some other way to achieve it.
In reply to Ammu89:
Since the restriction is on usage of fork join , I assume you are free to use
fork join_any and fork join_none
  initial   begin
           #2 ;
          $display("#2 Done") ;
          #4 ;
          $display("#4 Done") ;
      join
         $display("Fork  join  completes ");
The above fork join functionality can be achieved via ::
  initial   begin
           #2 ;
          #4 ;
      join_none
          wait_fork ;
Actually the question mentioned none of the fork-join, fork-join any Or fork join-none constructs should be used.
In reply to Ammu89:
We can’t answer the question without knowing what the desired results are.
In reply to Ammu89:
module test;
  event event_h;
  initial
      wait(event_h.triggered);
      $display("[%0t] Executing process 1",$stime);
  initial
      $display("[%0t] Executing process 2",$stime);
  initial
      #1;
      -> event_h;
Just a try, Not sure whether this is an appropriate answer.
The questioner asked only this much to me.
Without using fork-join constructs implement its functionality.
Thank you sai_pra99.
Solution is as best as possible, with only one problem.
For your code the simulated out put look as follows:
[1] Executing process 1
[1] Executing process 2
if the same was in fork-join the output would look as follows:
[0] Executing process 1
[0] Executing process 2
There is a clock cycle delay happening as we wait for the event to trigger. If there is a way to avoid that also, the solution is perfect.
thanks
In reply to Ammu89:
Yeah just remove that #1 delay, you get the desired result.I just added it without any intent.
In reply to Ammu89:
You can also use semaphore to sync up 2 threads or mailbox.
But to me, it is not good way that interviewer asks not to use language all features. This means that interviewer does not spend time to prepare good question.
It is like drive the car without using acceleration.
Think twice before accepting the offer.
In reply to haykp:
Love that analogy about driving a car; I’ve been searching for something like that.
Sometimes it’s more about about making sure you have enough information to attempt a solution rather than actually providing a solution.
A car can’t go from stationary to moving with acceleration. Did you really mean “without putting pressure on the accelerator pedal?”
If someone or something pushes my car from behind, or coast down a hill, is that still considered “driving”? Or does the car need to be self-propelled?
Back to the fork-join question, there are an infinite number of way to write code with a fork-join, and for some of those, removing the fork would have no change in the behavior.
initial fork
         $display("hello");
        join
Removing or replacing the fork/join with begin-end would not change the behavior. So I would have asked for a particular example of fork-join usage that they wanted implemented without using fork-join.
I came across this question and it looks like this implementation also works on the simulator without events and using tasks instead forked off across different initial begin blocks.
This can implement both the fork-join and fork-join_any construct. I seem to have tested this on simulator and it looks like this too works.
 module sv;
  integer i=0;
  initial begin : thread1
    task1();
    i++;
  end : thread1
  initial begin : thread2
    task2;
    i++;
  end : thread2
  initial begin // thread for fork_join
    $display("just before waiting time %0d", $time);
    // variation1: for fork_join need both thread1 and thread2 to complete
    wait(i==2); // wait till both the tasks complete
    $display("completed the wait at time %0d", $time); // execute this line only after both task1 and task2 which are forked off at same time.
    //you can add code here that can synchronize only after both complete.
  initial begin //thread for fork join_any
    // variation2: for fork_join_any to execute after any of the thread1 and thread2 to complete
    //NOTE: DONT USE wait(i==1) as they may be some race condition if both the threads complete at the same time and you may miss the trigger as it would jump from 0-> 2 directly if both start and end at the same time.
    wait(i>0); // wait till both the tasks complete
    //you can add code here that can synchronize after one of the thread works
  task task1();
    $display("inside task1 at time %0d", $time);
    #20;
    $display("completed task1 at time %0d, i:%0d", $time, i);
  task task2();
    $display("inside task2 at time %0d", $time);
    #30;
    $display("completed task2 at time %0d, i: %0d", $time,i);
