How can i connect two sequencers to regmodel
In reply to cgales:
The reason that i want to do it is im having 2 active agents which each one of them can write to those registers.
if i’ll do two register models each one of them will hold different database.
I need that if agentA write to register reg1 and agentb will read from this register then it will holds the same data that agentA has write.
