Hi all,
i am reading file line by line by using $fscanf system task but i want to check that which line contain x value if x value is received then give error message .
input file
5
-0.098974
x
0.666
0.988
x
eda link:
Hi all,
input file
5
-0.098974
x
0.666
0.988
x
eda link:
In reply to Prashant Soni:
you can use $isunknown(expression). if return 1 then value is x or z, otherwise it will return 0
In reply to kddholak:
thanks for your quick response…
plz first see eda link…
i want to read file using $fscanf system task but main problem is that …
when fscanf read int values from file then return value of $fscanf is 1
when fscanf read x value from file then return value of $fscanf is 0 after x value received when fscanf read int value then it’s giving 0(return value) instead of 1
how can i read floting point and x values from file in sv?
