The below code about the heartbeat monitor is not working as expected. Can someone help me to figure out the issue for the below code?
Code:
`include "uvm_macros.svh"
import uvm_pkg::*;
class my_catcher extends uvm_report_catcher;
uvm_phase phase;
`uvm_object_utils(my_catcher)
function new(string name = "my_catcher");
super.new(name);
endfunction : new
function action_e catch();
if(get_severity() == UVM_FATAL && get_id() == "HBFAIL") begin
uvm_objection obj = phase.get_objection();
`uvm_error("HBFAIL", $psprintf("Heartbeat failure! Objections:"));
obj.display_objections();
return THROW;
class my_env extends uvm_env;
`uvm_component_utils(my_env)
super.new(name, parent);
for(int i =0;i<20;i++) begin
`uvm_info("ENV", $sformatf("RAISE : Env i = %0d",i),UVM_NONE)
phase.raise_objection(this);
#10;
phase.drop_objection(this);
`uvm_info("ENV", $sformatf("Drop : Env i = %0d",i),UVM_NONE)
`uvm_component_utils(my_test)
my_env env;
env = my_env::type_id::create("env", this);
function void start_of_simulation_phase(uvm_phase phase);
super.start_of_simulation_phase(phase);
heartbeat(phase);
`uvm_info("TEST", "Inside Run phase..",UVM_NONE)
#200;
`uvm_info("TEST", "Ended Run phase..",UVM_NONE)
function void heartbeat(uvm_phase phase);
uvm_heartbeat heartbeat;
uvm_callbacks_objection my_objection;
uvm_event my_event = new("my_event");
uvm_component my_comps_q[$];
my_catcher catcher = my_catcher :: type_id :: create("catcher",this);
uvm_phase run_phase = phase.find_by_name("run", 0);
catcher.phase = run_phase;
uvm_report_cb :: add(null, catcher);
assert ($cast(my_objection, run_phase.get_objection()))
`uvm_fatal("run_phase", $psprintf("run phase objection type"));
heartbeat = new("activity_heartbeat",this,my_objection);
heartbeat.set_mode(UVM_ANY_ACTIVE);
heartbeat.set_heartbeat(my_event, my_comps_q);
heartbeat.add(env);
fork begin
forever begin
#25 my_event.trigger();
`uvm_warning("heartbeat",$sformatf("event triggered"))
end join_none
endfunction : heartbeat
// The top module that contains the DUT and interface.
// This module starts the test.
import uvm_pkg::*;
run_test("my_test");
Output :
Compiler version J-2014.12-SP1-1; Runtime version J-2014.12-SP1-1; Jan 2 11:05 2019
UVM_INFO /apps/vcsmx/etc/uvm-1.2/src/base/uvm_root.svh(402) @ 0: reporter [UVM/RELNOTES]
UVM-1.2.Synopsys
(C) 2007-2014 Mentor Graphics Corporation
(C) 2007-2014 Cadence Design Systems, Inc.
(C) 2006-2014 Synopsys, Inc.
(C) 2011-2013 Cypress Semiconductor Corp.
(C) 2013-2014 NVIDIA Corporation
*********** IMPORTANT RELEASE NOTES ************
You are using a version of the UVM library that has been compiled
with `UVM_NO_DEPRECATED undefined.
See http://www.eda.org/svdb/view.php?id=3313 for more details.
with `UVM_OBJECT_DO_NOT_NEED_CONSTRUCTOR undefined.
See http://www.eda.org/svdb/view.php?id=3770 for more details.
(Specify +UVM_NO_RELNOTES to turn off this notice)
UVM_INFO @ 0: reporter [RNTST] Running test my_test…
UVM_INFO testbench.sv(36) @ 0: uvm_test_top.env [ENV] RAISE : Env i = 0
UVM_INFO testbench.sv(64) @ 0: uvm_test_top [TEST] Inside Run phase..
UVM_INFO testbench.sv(40) @ 10: uvm_test_top.env [ENV] Drop : Env i = 0
UVM_INFO testbench.sv(36) @ 10: uvm_test_top.env [ENV] RAISE : Env i = 1
UVM_INFO testbench.sv(40) @ 20: uvm_test_top.env [ENV] Drop : Env i = 1
UVM_INFO testbench.sv(36) @ 20: uvm_test_top.env [ENV] RAISE : Env i = 2
UVM_WARNING testbench.sv(91) @ 25: uvm_test_top [heartbeat] event triggered
UVM_INFO testbench.sv(40) @ 30: uvm_test_top.env [ENV] Drop : Env i = 2
UVM_INFO testbench.sv(36) @ 30: uvm_test_top.env [ENV] RAISE : Env i = 3
UVM_INFO testbench.sv(40) @ 40: uvm_test_top.env [ENV] Drop : Env i = 3
UVM_INFO testbench.sv(36) @ 40: uvm_test_top.env [ENV] RAISE : Env i = 4
UVM_WARNING testbench.sv(91) @ 50: uvm_test_top [heartbeat] event triggered
UVM_INFO testbench.sv(40) @ 50: uvm_test_top.env [ENV] Drop : Env i = 4
UVM_INFO testbench.sv(36) @ 50: uvm_test_top.env [ENV] RAISE : Env i = 5
UVM_ERROR testbench.sv(21) @ 50: uvm_test_top [HBFAIL] Heartbeat failure! Objections:
UVM_INFO /apps/vcsmx/etc/uvm-1.2/src/base/uvm_objection.svh(1072) @ 50: run [UVM/OBJ/DISPLAY] The total objection count is 2
Source Total
Count Count Object
0 2 uvm_top
1 2 uvm_test_top
1 1 env
UVM_FATAL @ 50: uvm_test_top [HBFAIL] Did not recieve an update of run on any component since last event trigger at time 25. The list of registered components is:
uvm_test_top
uvm_test_top.env
UVM_INFO /apps/vcsmx/etc/uvm-1.2/src/base/uvm_report_catcher.svh(705) @ 50: reporter [UVM/REPORT/CATCHER]
— UVM Report catcher Summary —
Number of demoted UVM_FATAL reports : 0
Number of demoted UVM_ERROR reports : 0
Number of demoted UVM_WARNING reports: 0
Number of caught UVM_FATAL reports : 0
Number of caught UVM_ERROR reports : 0
Number of caught UVM_WARNING reports : 0
UVM_INFO /apps/vcsmx/etc/uvm-1.2/src/base/uvm_report_server.svh(847) @ 50: reporter [UVM/REPORT/SERVER]
— UVM Report Summary —
** Report counts by severity
UVM_INFO : 16
UVM_WARNING : 2
UVM_ERROR : 1
UVM_FATAL : 1
** Report counts by id
[ENV] 11
[HBFAIL] 2
[RNTST] 1
[TEST] 1
[UVM/OBJ/DISPLAY] 1
[UVM/RELNOTES] 1
[UVM/REPORT/CATCHER] 1
[heartbeat] 2
Thanks in Advance,
SANJAIKUMAR K
