Hi All,
While using the type overriding I got an error. Issue is the "newly added analysis port is not a class item ". Please help me to resolve the Issue.
The code as follows:
//Base monitor
class base_monitor extends uvm_monitor;
`uvm_component_utils(base_monitor)
//declaration of variables and analysis ports
function new(string name,uvm_component parent);
super.new(name,parent);
endfunction : new
super.build_phase(phase);
endfunction : build_phase
virtual function void connect_phase(uvm_phase phase);
//connections
endfunction : connect_phase
//code
endtask : run_phase
endclass : base_monitor
// extended monitor
class ext_monitor extends base_monitor;
`uvm_component_utils(ext_monitor)
//new analysis port declared
uvm_analysis_port #(seq_item) pkt_port;
pkt_port = new("pkt_port", this);
endfunction : new
endclass : ext_monitor
class base_agent extends uvm_agent;
uvm_active_passive_enum is_active = UVM_ACTIVE;
`uvm_component_utils(base_agent)
base_driver driver;
base_sequencer sequencer;
base_monitor monitor;
if(is_active == UVM_ACTIVE) begin
driver = base_driver::type_id::create("driver",this);
sequencer = base_sequencer::type_id::create("sequencer",this);
monitor = base_monitor::type_id::create("monitor",this);
driver.seq_item_port.connect(sequencer.seq_item_export);
endclass : base_agent
class ext_agent extends base_agent;
`uvm_component_utils(ext_agent)
function new (string name = "ext_agent", uvm_component parent = null);
super.new(name, parent);
endfunction : new
endclass : ext_agent
class module_env extends uvm_env;
`uvm_component_utils(module_env)
ext_agent active_agent;
ext_agent passive_agent;
function new(string name = "module_env", uvm_component parent = null);
endfunction : new
uvm_config_int::set(this,"active_agent","is_active",UVM_ACTIVE);
uvm_config_int::set(this,"passive_agent","is_active",UVM_PASSIVE);
active_agent = ext_agent::type_id::create("active_agent", this);
passive_agent = ext_agent::type_id::create("passive_agent", this);
super.connect_phase(phase);
function void end_of_elaboration_phase(uvm_phase phase);
super.end_of_elaboration_phase(phase);
endfunction : end_of_elaboration_phase
endclass : module_env
class top_env extends uvm_env;
`uvm_component_utils(top_env)
module_env env;
scoreboard scbd;
// Overriding
set_type_override_by_type(base_monitor::get_type(),ext_monitor::get_type());
env = module_env::type_id::create("env",this);
scbd = scoreboard::type_id::create("scbd",this);
env.active_agent.monitor.pkt_port.connect(scbd.pkt_import); // I am getting the Issue: "pkt_port is not a class item"
endclass : top_env
Thank you
