Hi Team,
I have downloaded UVM Package i.e. uvm-1.2 from accelera and trying to run the example given in the “uvm-1.2\examples\simple\basic_examples\pkg” from command line and getting following warning and error:
make -f Makefile.questa all
vlib.exe work
** Warning: (vlib-34) Library already exists at “work”.
vlog.exe -timescale “1ns/1ns” +define+UVM_NO_DPI -mfcu -suppress 2181 +acc=rmb -writetoplevels questa.tops …/…/…/…/src/uvm_pkg.sv +incdir+…/…/…/…/src +incdir+.
test.sv +define+UVM_NO_DPI
QuestaSim-64 vlog 10.6c Compiler 2017.07 Jul 26 2017
Start time: 15:58:14 on Aug 23,2024
vlog -timescale 1ns/1ns “+define+UVM_NO_DPI” -mfcu -suppress 2181 “+acc=rmb” -writetoplevels questa.tops …/…/…/…/src/uvm_pkg.sv “+incdir+…/…/…/…/src” “+incdir+.” test.sv “+define+UVM_NO_DPI”
– Compiling package uvm_pkg
– Compiling module test
– Importing package uvm_pkg
Top level modules:
test
End time: 15:58:15 on Aug 23,2024, Elapsed time: 0:00:01
Errors: 0, Warnings: 0
vsim.exe -c -do “run -all; q” -l questa.log -f questa.tops
Reading C:/questasim64_10.6c/tcl/vsim/pref.tcl
10.6c
vsim -c -do “run -all; q” -l questa.log -f questa.tops
Start time: 15:58:15 on Aug 23,2024
** Warning: (vsim-7076) The gcc/g++ path ‘/usr/bin/gcc’ via DpiCppPath modelsim.ini variable is not qualified and is ignored.
** Fatal: (vsim-7019) Can’t locate a C/C++ compiler for ‘DPI Export Compilation’.
FATAL ERROR while loading design
Error loading design
End time: 15:58:16 on Aug 23,2024, Elapsed time: 0:00:01
Errors: 2, Warnings: 1
make: *** [Makefile.questa:33: run] Error 12
I have explored verification academy forum before posting this.
Vinod
