While running the below code i am getting the warning as i have mentioned above :
typedef enum bit {vlsm0,vlsm1} vlsm_type;
typedef enum bit[1:0] {almp_flit,io_flit,null_flit,null_flit_eds} flit_type;
//typedef class flit_c;
class flit_c;
rand vlsm_type vlsm;
rand flit_type flit;
endclass : flit_c
class state;
int flit_cnt[vlsm_type][flit_type] = ;
function void call(flit_c pkt);
flit_cnt[pkt.vlsm][pkt.flit]++;
$display("cnt is for flit_cnt[%s][%s] = %0d",pkt.vlsm,pkt.flit,flit_cnt[pkt.vlsm][pkt.flit]);
endfunction : call
endclass : state
module my_m;
state state_c;
flit_c flit_cc;
state_c = new;
flit_cc = new;
repeat(4) begin
flit_cc.randomize();
state_c.call(flit_cc);
This is an expected warning as you are attempting to access an associative array member which doesn’t exist and that you will be getting the default value.
You could first check if the entry exists prior to attempting to access it to avoid the error.
