My test case body() task looks similar to below:
for (int i = 0; i <2; i++)
sequence_1.start(master_sqr[0]);
join_none;
sequence_2.start(master_sqr[0]);
join_none;
$display (“TEST PROGRESS: Before 500ns delay”);
#500ns;
$display (“TEST PROGRESS: After 500ns delay”);
join_none;
join_none;
When I run the test case, the following FATAL error is observed after the 500ns delay, when the sequence’s start is called the second time.
UVM_FATAL @ 1899059: uvm_test_top.m_m0s8peri_env.cm0_master_0.sequencer@@m0s8peri_seq_ahb_slave_16bit_access_seq[0] [SEQ_NOT_DONE] Sequence uvm_test_top.m_m0s8peri_env.cm0_master_0.sequencer.sequence_2 already started
Could someone help me understand what is wrong in the above piece of code ??
Regards,
