Get Type Name with Parameters?
Is it possible to printout the name of a type including the parameters that defined the type?
get_type_name() seems to print out the base class, even though I used `uvm_object_param_uitls()
In reply to raysalemi:
Not when you use the `uvm_object_param_util macros. See Parameterized Classes, Static Members and the Factory Macros - Verification Horizons for an alternative.
Hmm…I didn’t see the answer there. Did I miss it?
class B #(int w=1);
  static string name = $sformatf(“packet%0d”,w);
Aha. I get it.
But what if I’m using an enumeration as a type parameter.
Use $typename
