Please explain me about get_full_name & get_type_name in UVM. When and why they are used?
In reply to Geetika Reddy:
Hi Geetika,
If you use `uvm_info(get_full_name()…) then it will show the complete hierarchical path starting from tb_top.test.env… and so on till your object type in the output LOG file.
If you use get_type_name() then it will return only the class name irrespective of hierarchy.
If you use get_name() then it will return the string name you defined in the function new() constructor.
For more information, you can refer the uvm1.2 class reference at topic macros.
Mahesh.
