Get_event_pool usage
Hi All,
I’ve recently used uvm_event and I got it to work as I wanted by setting it in the uvm_config_db as follows :
class file1 extends uvm_sequence;
uvm_event event_name;
function new(string name="file1");
  super.new(name);
  event_name = new("event_name");
  uvm_config_db#(uvm_event)::set(null, "*", "pass_event", event_name);
endfunction: new
task some_task;
  //data manipulation
  event_name.trigger();
endtask : some_task
endclass : file1
class file2 extends uvm_component;
    uvm_config_dv#(uvm_event)::get(this, "*", "pass_event", event_name);
    forever begin
      event_name.wait_trigger();
      // do something
  endtask : run_phase
endclass : file2
This is working in my case. But I want to use get_event_pool instead. Can someone explain how does my code change if I use get_event_pool?
I was also wondering if it is a good practice to set uvm_event in config_db like shown above. If not, why do we have get_event_pool for? Are there any possible advantages or disadvantages in either case?
In reply to szy0014:
The uvm_event_pool manages a pool of events that can be accessed using a string name. Finally it is an associative array of uvm_events indexed by name (string). It allows accesses from multiple components.
See the code below:
class driver1 extends uvm_driver #(my_tx);
  uvm_event_pool ev_pool = uvm_event_pool::get_global_pool();
    uvm_event ev = ev_pool.get("driver1_ev");
    ev.trigger(req);
class driver2 extends uvm_driver #(my_tx);
    ev.wait_trigger();
    $cast(req, ev.get_trigger_data());
The name of the event is ‘driver1_ev’. The get command gets this event or creates one if it does not exist.
The get command in driver2 deals also with this event and waits for it. If it gets the event it is working with the data belonging to these event.
Hope this helps.
Thanks a lot. That helps.
Hi,chr_sue,
I am wondering whether there is a way to detect whether the event already exists?
Because might face give the wrong evetn_string and cause two different event created, hence can never wait the event to happen.
Is there a way to see the created uvm_event in uvm_event_pool?
BR
In reply to ProssM:
Maybe something like this could be used
`include "uvm_macros.svh"
  import uvm_pkg::*;
  uvm_event ev;
    ev = uvm_event_pool::get_global("ev_ab");
    #10 ev.trigger();
    $display("%t: event ev triggered", $time);
    string ev_name = "EVENT_X";
    // get a reference to the global singleton object by
    // calling a static method
    static uvm_event_pool ev_pool = uvm_event_pool::get_global_pool();
    // either create a uvm_event or return a reference to it
    if(ev_pool.exists(ev_name)) begin
      `uvm_info("TB", $sformatf("event named = %s EXISTS", ev_name), UVM_NONE)
    else begin
      `uvm_info("TB", $sformatf("event named = %s DOES NOT EXISTS",ev_name ), UVM_NONE)
    ev_name = "ev_ab";
    else begin
    // wait for the trigger
    ev.wait_trigger();
    $display("%t: event ev trigger received", $time);
# KERNEL: UVM_INFO /home/runner/testbench.sv(25) @ 0: reporter [TB] event named = EVENT_X DOES NOT EXISTS
# KERNEL: UVM_INFO /home/runner/testbench.sv(31) @ 0: reporter [TB] event named = ev_ab EXISTS
Please note in this code there could be a race condition between the two threads
HTH,
-R
In reply to rgarcia07:
Thanks.
This can work if two uvm_event are in the same event_pool.
But what if there are multiple pools.
Is there a way to get all existing pools?
In reply to ProssM:
You can use ev_pool.exists(“event_name”) which returns true if it exists.
https://verificationacademy.com/verification-methodology-reference/uvm/docs_1.2/html/files/base/uvm_pool-svh.html
In reply to ProssM:
Thanks.
There is no method available which reports all event names used. In any way you have to search for specofoc names.
