Generating sequences based on activity on other interfaces
Got it. You care about determinism from a monitor report to a sequence/driver activity reacting to that, where both are on the same clock edge.
  1. add some SV code to deal with that, on a case by case basis. In the past I have used the negedge of the clock for this, knowing that all consequences of the previous activity have settled down by then. Call it a ‘setup time’ of sorts.
  2. Manually adding delays is almost always not a good solution.
  3. I don’t think NBA is useful here but we have not had NBA in classes before so a new pattern may emerge. Let us know if you invent something that works for your use case.
  4. Some situations will not be ideal for a shared config object. If you need a ‘communication channel’ use an analysis port on the monitor/scoreboard and have your sequencer subscribe to updates from it, so you know the update was sent before you make a decision based on it.
There is no mechanism in the UVM config provision that can help here (which I think is a good thing. If UVM added one, it would slow down config object access for everyone)
Finally, consider instead orchestrating your stimulus from above (a virtual sequence calling sequences) to achieve your verification objectives without needing this link.
