dave_59
September 8, 2017, 7:12pm
41
In reply to edaboy :
Are you sure you are not getting any other warnings or error messages before the displayed output. The tool you are using has lots of problems. Consider a different tool or upgrading to a more recent version.
The first constraint should be an error because it would try to create the constraint num[10] !=num[9], and num[10[ is out of bounds. You need to write it as
constraint rand_num{foreach (num[i]) i+1 < $size(num) -> num[I+1] != num[i];};
The other two constraints work for me.
edaboy
September 8, 2017, 9:01pm
42
In reply to dave_59 :
Thanks Dave for quick reply. I did not see any error or warning. I still see weird behavior with code that you asked me to modify. However with that code i see that both the other constraint works fine.
notice that i modified code , converted bit to int and i want to make sure int are generated in specific range. is it a proper way to do it? or any other better way can you suggest ?>
constraint rand_num{foreach (num[i]) i+1 < $size(num) → num[I+1] != num[i];};
rand int unsigned num [10];
rand int unsigned data[10];
rand int unsigned uniqnum[10];
constraint rand_num{foreach (num[i]) i+1 < $size(num) -> num[i+1] != num[i];
foreach (num[i]) num[i] inside {[0:20]};
constraint data_values { foreach(data[i])
foreach(data[j])
if(i != j) data[i] != data [j] ;}
constraint rand_unitnum{unique {uniqnum};}
[\systemverilog]
num[0] 11
num[1] 10
num[2] 5
num[3] 18
num[4] 1
num[5] 8
num[6] 17
num[7] 6
num[8] 17
num[9] 12
uniqnum[0] 2585900447
uniqnum[1] 2885502533
uniqnum[2] 4138482668
uniqnum[3] 3688754642
uniqnum[4] 565161356
uniqnum[5] 3727708039
uniqnum[6] 1611526103
uniqnum[7] 1088663520
uniqnum[8] 405083532
uniqnum[9] 1919651944
data[0] 3040365644
data[1] 1549177249
data[2] 2520948884
data[3] 671157517
data[4] 3642241582
data[5] 1668691443
data[6] 2694328522
data[7] 616240321
data[8] 2242663180
data[9] 3757757259
Hi Dave ,
How to generate unique values for array of array without using unique ?
constraint c {
foreach(fx_arry[i]) {
// fx_arry[i] inside{[0:SIZE-1]};
foreach(fx_arry[j]) {
if(j != i){
fx_arry[j] !=fx_arry[i]
I am unable get the logic right .can you help out.
In reply to rambarki.satish :
It seems to be a typo Satish.
constraint fx_arry_size_c{
fx_arry.size() inside {[1:100]};
constraint uniq_c {
if(j != i){
fx_arry[j] !=fx_arry[i];
In reply to deepthig :
I didn’t get the expected output after using the above approach.What is wrong in my code
class a;
rand bit [3:0]a[15];
constraint uniq_c {
foreach(a[i]) {
foreach(a[j]) {
if(j != i){
a[j] !=a[i];
a.shuffle();
module test;
a a_i;
int temp,i=0;
a_i = new();
foreach(a_i.a[i])begin
a_i.randomize();
temp=a_i.a[i];
$display("array value[%d] =%d",i,temp);
#100;
output:
array value[ 0] = 3
array value[ 1] = 5
array value[ 2] = 3
array value[ 3] = 6
array value[ 4] = 5
array value[ 5] = 4
array value[ 6] = 10
array value[ 7] = 8
array value[ 8] = 4
array value[ 9] = 14
array value[ 10] = 1
array value[ 11] = 7
array value[ 12] = 11
array value[ 13] = 15
array value[ 14] = 13
dave_59
February 21, 2019, 4:18am
46
In reply to Bharat100 :
Move
a_i.randomize(); in front of the foreach loop. Also, there is no need to shuffle() the array.
That was my fault You are right. Thank you Dave.
