Hi Dave, i have a new question that is related but it is a little different. I haven’t found any solution in the forum so maybe you can help.
What i want is to generate an array with unique ranges. This is typically useful for addressing ranges that are not overlapping. What is the best and efficient way to do that?
In a paper of the DVCon from Mentor i have seen: http://proceedings.dvcon-europe.org/2014/presentations_and_papers/T5_1_paper.pdf
There is the following code:
rand bit [31:0] start_addr;
rand bit [5:0] length;
bit [31:0] start_end_addr_hash [bit[31:0]];
constraint c { //Generate Non-Overlapping address ranges
if (start_end_addr_hash.num()) {
foreach (start_end_addr_hash *) {
if (i >= length ) {
!(start_addr inside {[i-length+1 : start_end_addr_hash [i]]});
} else {
!(start_addr inside {[0 : start_end_addr_hash [i]]});
length == 6'h10;
start_end_addr_hash [start_addr] = start_addr + length - 1;
Is that the best way? Besides, it is not clear for me where i have to put the code.
Another option is using only random variables. The advantage is that the user can define the start and length by himself for each non overlapping part ([i]notice that it uses a dynamic array and not only one value for start_address and lengt*h). I think the previous example doesn’t allow you to do that because is all coded in the hash iteratively.
Besides, if you do constraint “length[j]==1” then this code generates a vector with unique values in the start_address. That means, this somehow supersedes the codes above at cost of efficiency and memory.
rand bit [31:0] start_address[]; //notice that it is a dynamic array
rand bit [5:0] length[]; //dynamic array, to specify many different ranges
constraint c {
start_address.size()==length.size();
if (start_address.size()) {
foreach (start_address[j]) {//j is the chosen start address
// end_address [j] == start_address[j] + length[j] - 1;
foreach (start_address[i]) {//i is the chosen start address
if (i!=j) {
///Constraint start_address (first byte of the buffer)
if (start_address [j] >= length[i] ) {
!(start_address[i] inside {[start_address [j] - length[i]+1 : start_address [j]+length[j]-1 ]}) ;
} else {
!(start_address[i] inside {[0 : start_address [j]+length[j]-1 ]});
} //end if i!=j
} //end foreach i
} //end foreach j
} //end if
} //end contraint c
In the paper’s example, the constraint about the length (i.e. length==6’h10) is just for demonstration, you can remove that to get the variable length you want. In reality length limitation constraints do exist. And yes you can add the following line in any procedural block after a successful randomization attempt (post_randomize is a good place).
Back to the debate about performance, the introduced example (second one) shall generate all address ranges upfront. Although I am fan of late-randomization (randomize at the right time to take the DUT and testbench states into consideration), this is not just the problem I see with the second code. The second code has a nested foreach loops, this is a solver performance overkill, especially if size of the arrays are large enough. An interesting exercise is to measure the time the solver will solve the second example with array sizes of 100 and above.
The first code (code in the paper) kind of escape from this problem by only randomizing a single attempt at a time, then saving the start and end addresses in a hash table acting as a back-log/guiding reference for the next randomization attempt. Hence only one foreach is used in constraint, which still possess a performance bottleneck, however much faster than the second solution.
That said, if I were to write the code I would neither use the first nor the second solutions to solve the simple problem of non-overlapping address ranges. I would just remove the constraint completely and embrace the constraint with a checking loop like so.
class c;
c c1 = new;
forever begin
duplicate = 0;
assert(c1.randomize());
foreach (c1.start_end_addr_hash [i])
if ((c1.start_addr <= c1.start_end_addr_hash [i]) && ((c1.start_addr + c1.length -1) >=i )) begin
duplicate = 1;
break;
if (!duplicate) break;
c1.start_end_addr_hash [c1.start_addr] = c1.start_addr + c1.length - 1;
The code above shall free the solver from complicated constraints allowing it to focus on the distribution. If we assumed an ideal solver distribution (e.g. BDD solver will be efficient to solve the simplified problem above), the third solution will be much faster than both solutions above (especially the second one).
Same stands true for the original question of this post; how to generate an array of random unique elements. Well you can also use procedural code and minimal solver work if possible, like so:
class dummy_c;
randc bit [31:0] val;
class trans;
rand bit [31:0] addrs [];
dummy_c dc = new;
foreach (addrs[i]) begin
assert (dc.randomize);
addrs[i] = dc.val;
Thanks for your detailed answer. I agree with you. For long vectors your last solution has much better performance. Thanks for the insight in the constraint solver performance.
I have also noticed that if we would have been talking about a transaction item class, then the user can also create random variables and a flag (e.g. fullrandom_or_definedbyuser) so that he can assign their user-values in the post randomization phase. In that way, the user can decide if he want to find a new solution (using your last code) or test a previous solution defined (hardcoded) in the explicit part of the item randomization.
For example:
class c;
rand bit [31:0] start_addr[];
rand bit [5:0] length[];//size of
rand bit user_define_all_rand_members=0;
constraint c {
length.size()==start_addr.size();
soft user_define_all_rand_members==0;
} //end contraint c
c c1 = new;
repeat(number_of_blocks2generate) begin
forever begin
duplicate = 0;
assert(c1.randomize( ) with {
start_addr.size()==2;
user_define_all_rand_members==1;
start_addr = { 32'hFFFF, 32'h0000 };
} );//try to add a block of 2 ranges, you can define more
//Start check of the random value
foreach (c1.start_end_addr_hash [i]) begin
foreach (c1.start_addr [j]) begin
if ((c1.start_addr[j] <= c1.start_end_addr_hash [i]) && ((c1.start_addr[j] + c1.length[j] -1) >=i )) begin
duplicate = 1;
if (user_define_all_rand_members==1) begin
$fatal (0, "Randomization defined by user failed")
break;
//ADD A NEW RANGE-ELEMENT START->END ADDRESS TO THE ASSOCIATIVE ARRAY
if (!duplicate) begin
c1.start_end_addr_hash [c1.start_addr[j]] = c1.start_addr[j] + c1.length[j] - 1;
end//end for associative array
end//end forever begin
end//end repeat number of blocks to add to the associative array
With this version, the user can still defines/direct the randomization with several ranges in one shot (using the with clause). These “with” constraints are checked by the forever loop without using the constraint solver, improving the performance.
In reply to mseyunni:
You have declared dcd2pdw as an associative array whose index type is bit[DCD_INDEX_BITS-1:0]. You cannot randomize the size of an associative array. Did you mean to declare a fixed sized array?
Hi Dave, does this mean that an associative array cannot be randomized? If it can be, can we have constraints on elements of the associative array? What happens when a rand object containing an associative array is randomized?
You can randomize the existing elements of an associative array, just like any other array using the foreach constraint. You cannot add or delete elements, or change the index values of an associative array.
class A;
bit [PDW_INDEX_BITS-1:0] used_dcd2pdw[$][2**DCD_INDEX_BITS];
rand bit[PDW_INDEX_BITS-1:0] dcd2pdw[2**DCD_INDEX_BITS];
constraint uniq {unique {dcd2pdw,used_dcd2pdw};}
function void post_randomize;
used_dcd2pdw.push_back(dcd2pdw);
endclass:A
The uniq constraint will eventually fail after so many calls to randomize(). I’ll leave it to you to figure out what to do when it does.
Hi dave,
I tried to use that but a compile error says that the other array is not rand.
This is my code:
program try_unique_array();
class unique_array;
rand bit [3:0] arr[16];
bit [3:0] excludes[4] = {0,5,4,3};
constraint array_elements_should_be_unique {
unique {arr, excludes};
endclass : unique_array
unique_array ua;
ua = new();
assert(ua.randomize());
foreach(ua.arr[i]) begin
$display("ua.arr[%0d] = %0d", i, ua.arr[i]);
endprogram : try_unique_array
In reply to Reuben:
I don’t get a compiler error when I run this in Questa. I do get an assertion error when I run this because the randomization fails. That is because you are excluding 4 values which leaves only 12 possible values of a 4-bit number that could be unique. So you need to change your array declaration to arr[12].
In reference with discussion going on unique constructs i have few points as a query.
I have compiled & executed this below simple code to check the sv-2012 unique construct.However it is executing successfully with VCS 2014.10 but for cadence incisive 15.20 it is reporting an error like below::
ncvlog: *E,MSTBER (design.sv,5|38): Expecting a random variable (declared with the ‘rand’ modifier).
Is it having possibility like we have to pass some switch to enable 2012 constructs?
Also the concept of unique is related only with randomizing unique array elements or it has some other use cases as well apart from array randomizing?
class dummy;
rand bit [3:0] mode[5];
bit[3:0] exludes[]={1,2,3,4,5,6};
constraint uniq{unique {mode,exludes};} //excluding elements
endclass : dummy
module test_unique;
dummy clkgen = new();
clkgen.randomize();
for(int i=0;i<5;i++)
$display("clkgen.mode = %0d\n",clkgen.mode[i]);
It seems Incisive has a problem with the unique constraint or it is caused by a weakness in your code. You should clean-up your code in test_unique:
(1) make the declaration of clkgen outside of the inital block.
(2) construct clkgen in the initial.
It works fine with Questa.
unique is not a simple keyword. It defines the so-called ‘Uniqueness constraints’.
See chapter 18.5.5 in the SV Standard 2012.
hi sir,
i would like to generate the randomize array value with constraint method in sv.
for example
0_th location store the array value is 0…;
1_th location store the array value is 5,10,15…;
2_th location store the array value is 6,12,18…;
3_th location stote the array value is 7,14,21…;
4_th location stote the array value is 8,16,24…;
5_th location stote the array value is 9,18,27…;
program main;
A a;
bit k;
a=new();
k=a.randomize();
$display(“k=0%d”,k);
foreach(a.data[i])
$display(“data[%0d]=0%d”,i,a.data[i]);
endprogram
To be honest this has nothing to do with randomization. You want to generate data following a certain rule. For this reason you should write your algorithm Meeting your requirements-
How would you initialize (in SV) a two dimensional array (4x3) to all numbers from 1 to 12 in a unique manner? This is how I wrote it, but I am sure there are more efficient ways, besides, I am not even sure if what I wrote below would work! Thanks in advance!
rand byte my_array[4][3];
int my_q[$] = {1,2,3,4,5,6,7,8,9,10,11,12};
int max_idx =11;
int idx = $urandom_range(11,0);
for (int i=0; i<4; i++)
for (int j=0; j<3; j++) begin
my_array[i][j] = my_q[idx];
my_q.delete(idx);
max_idx--;
idx = $urandom_range (max_idx,0);
Thank you Dave. Sure, I will, but I have a follow up question. How would you achieve the same result using shuffle() function? I did this, but it only shuffled the rows and not the columns!
module init_array;
int k = 1;
my_array[i][j] = k++;
my_array.shuffle();
In reply to vnaraghi:
Because SystemVerilog has arrays of arrays - not really multi-dimensional arrays. All the unpacked array methods work on one dimension at a time.
You could create an array with one dimension of 12 elements; shuffle that array; and then fill my_array with that.
num[*] is not all unique numbers as foreach loop check only next number to compare . look at num[7] and num[9] both are 13. What is the best stretagy to have all unique number generated without unique constraint ? i looked at other solutions too where shuffle() is used but what if we need to generate big addressing range for e.g.?
all output of uniqnum is 0 that means my tool does not support that built in functionality ?
i tried other constraint mentioned in this post for data[*] but it is all 0s Any suggestion why it is 0 ?
