Generate the sequence using constraint
Generate a constraint for the sequence 101100111000… without using pre and post randomize
This exact question was asked two days ago.
Below generic logic works
module example;
  // 16-bit wide vector, adjust size as needed
  logic [15:0] bitstring;
  // Constraint to ensure the condition that for each number of `1`s,
  // the number of `0`s following them is equal or greater.
  constraint ones_zeros_constraint {
    // Count number of ones and zeros
    int ones, zeros;
    // Find number of ones and zeros
    ones == $countones(bitstring);
    zeros == bitstring.size() - ones;
    // Ensure that the number of zeros is at least as many as ones
    zeros >= ones;
  // Test stimulus to generate random valid bitstrings
    // Apply the constraint and print the generated bitstring
    foreach (bitstring[i])
      bitstring[i] = $random;
    // Display the random bitstring
    $display("Generated bitstring: %b", bitstring);
    assert(ones_zeros_constraint) else $fatal("Constraint failed!");
```verilog
