Hi, I am trying to generate a simple Packet class that has a variable length (2 to 5 bytes long) payload with an an additional constraint that the sum of all payload bytes is 100.
I tried this code in edaplayground
module test();
class pkt;
rand bit[7:0] payload[];
constraint c1 {payload.size inside{[2:5]};}
constraint c2 {payload.sum==100;}
int i;
pkt p_h = new();
if(p_h.randomize())
for(i=0;i<p_h.payload.size;i++)
$display("Size is %0d with %0dst element is %0d", p_h.payload.size,i+1,p_h.payload[i]);
The output I’m seeing is :
Size is 2 with 1st element is 163
Size is 2 with 2st element is 193
I need the sum to be 100 in decimal. But it is considering hex. Can you please suggest me what to do.
below should work fine , i tried in EDA playground and its giving expected results.
class payload;
constraint size {
payload.size() inside {[2:5]};
constraint sum {
payload.sum() with (int'(item)) == 100;
payload pd;
pd = new();
for (int i = 0 ; i < 5; i++) begin
if (pd.randomize()) begin
foreach (pd.payload[i]) begin
$display ( "VALUE AT %0d is %0d" , i ,pd.payload[i]);
else $display("Randomization failed!");
we are representing each payload item with 8 bits which are sufficient to hold a sum value of 100. so why is this working only if we cast the item to be of int type in the constraint?
Because item represents the actual payload element so item width == payload array element width = 8 bits which should hold the sum 100
Because if you add 2 8-bit numbers together, the result is an 8-bit sum. 163+193 is 8’hA3 +8’hC1 = 8’h64. You would need to cast each element to 11 bits to add 5 8-bit array elements without overflow.
