So, suppose I have a macro define that comes from somewhere else and can take many integer values:
`define NUM_OF_THINGS 32
Now, what I want to have is another macro define that can concatenate that ‘32’ into its name:
`define THINGS_32
How do I generate the second macro based on the value of the first?
cgales
February 27, 2019, 12:42pm
2
In reply to rodrigoportella :
Section 22.5.1 of the SystemVerilog LRM describes the use of `define:
A `` delimits lexical tokens without introducing white space, allowing identifiers to be constructed from arguments. For example:
`define append(f) f``_master
An example of using this `append macro is:
`append(clock)
This example expands to:
clock_master
The reason I want to have the second macro is to actually include/exclude portions of code using an ifdef. Therefore
NUM_OF_THINGS can take values like 32, 16 or 4 and I want to test:
`ifdef THINGS_32
... instantiate a special class
`elsif THINGS_16
... intantiate another class
`elsif THINGS_4
do nothing
`endif
in order to include or exclude functionality.
Would that be possible?
dave_59
February 27, 2019, 10:01pm
4
You cannot derive a macro name by using the contents of another macro.
There might be a completely different way to approach what you want to do. Please explain with a minimal example what you in the end generated.
Hi rodrigoportella,
You can refer below code :
// Code your testbench here
// or browse Examples
define XYZ \
define THINGS_```NUM_OF_THINGS 1
`XYZ
$display(`THINGS_32);
