I want to generate a clock with 8 MHz frequency and stop the clock when condition is true and restart the clock again after certain conditions after a delay.
tb_clk = 1'b0;
wait(top_smps_state == 3'b001)
tb_clk = 1'b1;
forever begin
if(top_hsesel==0 && top_hsesel_done==0)begin
#FREQ_8MHZ tb_clk = ~tb_clk;
end else if(top_hsesel==1 && top_hsesel_done==1)begin
@(posedge top_clk_hse);
end else begin
tb_clk=0;
This code is hanging . Please provide a solution
In reply to kulua:
Your code is hanging because whenever the condition top_hsesel==1 && top_hsesel_done==0 or top_hsesel==0 && top_hsesel_done==1 occurs, the forever goes into an infinite zero-delay loop.
It is hard to give you a solution because your code is much more complicated than your description. (There are 3 conditional expressions in your code and 2 in your description, and no mention of @(posedge top_clk_hse) ). May this will work.
forever begin : outer_loop
tb_clk = 1'b0;
tb_clk = 1'b1;
forever begin : inner_loop
end else begin
break; // out of inner loop
end : inner_loop
end : outer_loop
You could sill get into am infinite loop hang if the condition (top_smps_state == 3’b001) is true when you break out of the inner loop.
