Functional coverage
Hi All, please go through code below:
covergroup cg @(cov_ev);
coverpoint addr{
               bins min[] = {32'h0000_0000:32'h0000_FFFF};
               bins mid[] = {32'h1_0004:32'h1000_FFFF};
               bins max[] = {32'hF000_0000:32'hFFFF_FFF0};
endgroup
i am getting the error as the range is overlapping for the bins min and mid.
can anyone suggest me the solution for the overlapping range in min and mid.
regards,
vinay
In reply to kumar-vin:
I’m getting a different error. You are missing 's around your ranges. Also addr needs to be at least 30 bits.
Hi dave,
addr is declared as bit[31:0] addr; // it is a class property
coverpoint addr{
bins min = {[32’h0000_0000:32’h0000_FFFF]};
bins mid = {[32’h1_0004:32’h1000_FFFF]};
bins max = {[32’hF000_0000:32’hFFFF_FFF0]};
endgroup
coverpoint addr{
endgroup
regards,
vinay
bins min[] = {[32'h0000_0000:32'h0000_FFFF]};
Isn’t it creating 65535 different bins? I think your intention is to create 1 bin for min range. If that is the case you should omit [] from the declaration and make it
bins min = {[32'h0000_0000:32'h0000_FFFF]};
