What is your question? It is possible that your coverage model isn’t sufficient enough or that all of your tests result in the same functional coverage. If this is the case, when you merge all of your tests, you will see no difference in total coverage.
You can use Questa to rank your tests to determine their effectiveness. If you only have one test that contributes and the others duplicate the same coverage, the ranking report will identify this.
i got my answer … every time i was getting the same result due to duplicate result for all test cases…the value of signals were not updating in the coverage report so all the test cases give same result and after merging also it was giving same % …
