At subsystem or SOC verification level,
let’s say there are three IPs integrated : IP1, IP2 and IP3.
Individually from block level verification, all IPs functional coverage is achieved 100%.
IP1 FC 100%
IP2 FC 100%
IP3 FC 100%
But at the subsystem level, when I run some tests or regression, functional coverage is still 60 to 70%. What would be the understanding here?
case_1 : We need to still add tests to make 100% coverage even at SOC level
case_2 : Getting coverage (code or FC) 70% at SOC level is still acceptable, no need to wait for 100% coverage since individually all IPs are already verified.
So, Now I need to sign-off. Can I proceed with just 70% coverage at SOC level,
requesting everyone to share thoughts here.
I am interesting in measuring sign off factors at SOC or sub system level.
As of my knowledge 100% IP-level coverage doesn’t guarantee the correctness of subsystem. 70% coverage is insufficient for signoff. you might missed some integration bugs. if you should Sign-off at the SoC level, you should have 100% functional coverage, code coverage and assertions.
The question is how did you specify the SoC level functional coverage?. And you should have in mind even reaching 100% IP-level coverage might be wrong because you have poor coverage model.
