Hello,
I understand that this phase_ready_to_end function can be used in scoreboard perhaps, to extend the time for the last transaction to be completely done instead of floating around. But I have one question - if this is a “function”, which is supposed to not “take time”(unlike a task), how/why does it allow us to extend time with the phase.raise/drop objection mechanism?
Is “wait_for_ok_end” function user-written and internal to the scoreboard which just sets the “is_ok_to_end” bit?
function void phase_ready_to_end( uvm_phase phase );
if( !is_ok_to_end() ) begin
phase.raise_objection( this , "not done yet" );
fork begin
wait_for_ok_end();
phase.drop_objection( this , "ok to end phase" );
join_none
endfunction : phase_ready_to_end
In reply to UVM_learner6:
phase_ready_to_end is a function, but there is a fork/join_none around the wait and drop routines. That allows the function to return immediately.
Yes, is_ok_to_end() and wait_for_ok_end() are routines in the scoreboard just as an example.
To use phase_ready_to_end in the scoreboard. Should the scoreboard have run_phase? I just have write functions with items collected through multiple monitors. When I had phase_ready_to_end defined in the scoreboard, I see that it is not called at all from the log. Is there something I am missing?
Every phase defined in a uvm_component gets called as well as calling phase_ready_to_end() at the end of every task based phase (a dozen or so) in classes derived from uvm_component. This happens regardless of whether you provided an override to the method or not.
