I wanted know whether if the following scenarios are possible:-
- Suppose if I define a constructor inside a class and then define a virtual function inside the same class…So can we call the virtual function inside the constructor, considering that the function is defined after the constructor.
- Also can the order of defining a constructor has to be always before the function or if we do it vice versa will it create any error.
