Function Call in Constraints
Hi all ,
I have the following code ::
class constraint_container;
  rand int unsigned  a ,b, c ;
  function int unsigned get_a();
    $display("I am in get_a");
    return a;
  function int unsigned value_of(int unsigned value);
    $display("I am in value_of");
    return value;
  constraint a_constraint {
    a == 5;
    // I expect "c" will be equal to "a"
    c == value_of(a);
    // I expect "b" to be equal to "a", but, surprise, surprise...
    b == get_a(); // Is this Valid ??
`ifdef M1  solve a before b , c; `endif
    automatic constraint_container cc_inst = new();
    void'(cc_inst.randomize());
    $display($sformatf("a: %0d, b: %0d, c: %0d", cc_inst.a, cc_inst.b, cc_inst.c));
OUTPUT On Simulator 1:
I am in get_a
I am in value_of
a: 5, b: 0, c: 5
OUTPUT On Simulator 2:
I am in get_a
I am in get_a
I am in get_a
I am in value_of
I am in get_a
a: 5, b: 0, c: 5
OUTPUT On Simulator 3:
Error on Line :: b == get_a();
[Q1] Is there any Error with b == get_a(); ?
[Q2] Do functions get_a() and value_of(a) have Same Priority ? . Since one has rand variable as argument , other doesn’t
[Q3] Using +define+M1 , We still get the Same Results , Shouldn’t it alter the Results ?
[Q4] Declaring a as randc [Without +define+M1] I expected a to be solved First , but it still gave same results . Shouldn’t that give all 3 variables as 5 ?
Regards,
AGIS
In reply to Etrx91:
[A1] The LRM requires that functions in constraints have no side-effects, and technically $display is a side effect.
[A2] Ordering is based on input arguments. You have broken that ordering by referencing a inside the function directly.
[A3] No. The function calls implicitly create the same ordering.
[A4] Since get_a() has no arguments, it is treated as a state variable and has no ordering.
Thanks for the reply . Also I have one more question ,
Difference between solve before and Variable ordering implied by Function arguments .
LRM says :: " In SystemVerilog, the behavior for variable ordering
implied by function arguments differs from the behavior for ordering specified using the
“solve…before…” constraint; function argument variable ordering subdivides the solution space thereby changing it. "
[Q] Is the subdivision in solution space due to the logic inside the Function ?
Simple solve before construct would simply pick a value for a rand variable first , thus changing only the probability of occurrence but not the solution space .
[Q] Is my understanding correct ?
In reply to Etrx91:
The solver treats the function as a black box. Presumably you have written a function because you could not express the logic as an equation.
I agree with what you said about solve-before
In reply to Etrx91:
Hi Dave ,
On checking again I saw Simulator 3 throws an error at " return a " of function get_a() which may be a side effect. The $diplay() within the 2 Functions works ( on Commenting return a )
Regards,
AGIS
In reply to Etrx91:
The generally accepted behavior for a side-effect in software is modifying something outside the scope of the function, Accessing something outside is not a side effect. But since as you have discovered that only the inputs to the function are looked at for ordering, this is poor programming in any case.
Hi Dave ,
Was going through the forum for functions in constraints examples and saw this example .
Shouldn’t b be 5 too in the output ? .
" Since get_a() has no input argument it has no ordering " .
Since a will be solved first due to implicit ordering shouldn’t get_a have returned with value of a as 5 ?
get_a() would have been called after value_of() due to lack of input argument to it and hence a would have been updated .
Thanks.
In reply to Have_A_Doubt:
No ordering means no implicit and no explicit ordering.
Unfortunately I am still unable to understand , need some more help :
   b == get_a() ;
 // Is Equivalent to
   b == a ;
So shouldn’t b be equal to 5 ? . Since in the output b == 0 , it seems as if the constraint on b gets solved even before a == 5 which is contrary to the statement
" Constraints are solved parallel to each other "
Thanks ,
{ b == get_a(); } is not an equivalent constraint to writing { b == a; }. That was the point of earlier replies. See section *18.5.12 Functions in constraints* in the 1800-2017 LRM.
