Function call; fields of the object have junk value
Hello,
I have the following code:
class Packet extends uvm_object;
  `uvm_object_utils(Packet)
  bit[7:0] opcode;
module TB;
  function void B();
     Packet temp_pkt;
     temp_pkt = new();
     temp_pkt.opcode = 'h2;
     A(temp_pkt);
   function void A(Packet pkt);
     pkt = new();
     $display(“Opcode value is %b \n”, pkt.opcode);//junk is printed here; why?
  function void run();
    B();
    run();
Any idea why I am not able to print opcode?
Thanks!
In reply to Verif Engg:
Because you are creating a new pkt object with “pkt = new();” in the function A(), before $display.
In reply to S.P.Rajkumar.V:
Thanks.
The same problem occurs even if I remove “pkt = new();” :(
Not sure what I am missing
Definition of new() is missing in your Packet class.
Add the following:
function new(string name = “Packet”);
super.new(name);
endfunction : new
and also you need to remove “pkt=new();” in function A();
Check here. Opcode of 'h2 is displayed as output after commenting pkt=new(). What are you really expecting?
Thanks ! Appreciate the link
