You simply express your parameter values as real numbers (32.0 and 1000.0) and you parameters will inherit they real type. And/or you can explicitly declare your parameters with a real type.
parameter real UVC_CLK_FREQ = 32; // MHZ
parameter real UVC_CLK_PERIOD = 1000/UVC_CLK_FREQ; // ns
Note when you use a an expression in a delay, it’s going to get scaled to the current timescale and truncated by the time precision. You may want to write this as
parameter real UVC_CLK_PERIOD = 1000ns/UVC_CLK_FREQ;
always #UVC_CLK_PERIOD clk = !clk;
