Frame Check Sequence or Parity Checker code in efficient way in SystemVerilog?
Hello Folks,
Can anyone comment on writing a short/effective way of coding the parity check or the frame check sequence that gets added along with any packet protocol for data integrity check ? Kindly share the same.
Thanks !
In reply to desperadorocks:
Parity check is defined in the requirements. Reduction XOR operator (e.g., ^data) or reduction XNOR operator (e.g., ~^data) can be used for parity of a data word.
For frame check sequence that gets added along with any packet protocol, it is typically a running sum (with overflow) of the data words in a packet, and that is checked against the sum that was provided in the packet. All of this should be specified in the requirements.
  • SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
