task ABC;
wait (condition) begin
join_any
task CDE;
join_any
- In this task ABC wait statement finish execution and goes in the task CDE wait statement , in the background it is still checking for the task ABC remaining wait statements and that gets executes. So how to stop fork join_any to run in the background. i used disable fork and disable with label name but that is not working for me.
- for all the wait statements how to put timeout condition to stop the execution once timer is done.
In reply to bijalthakkar:
I assume somewhere you have
ABC();
CDE();
You should have been able to put diable fork statement before the end of each task. You need to explain what “not working” means.
A timeout would be just another condition
task ABC;
#timeout_delay;
join_any
disable fork;
Also, yo need to make sure there is no semicolon between the wait (condition) and the begin end. Otherwise that creates two processes instead of one.
Thanks for the response.
yes their are multiple wait statements in each task waiting for the same condition. I am not using ; after the wait statement.
// clk generation
b<=1'b1;
c<=1'b1;
task A;
wait(condition=b) begin
B;
wait(condition=c) begin
C;
wait(condition=d) begin
D;
join_any
task B;
C1;
D;
wait(condition=e) begin
E;
join_any
Here in the top I am driving b=1’b1 so wait statement is satisfied and it will go to task B. Then i am driving c=1’b1 so it is expected that as it is task B it will make task B’s condition=c and call the task C1 and not the task A’s condition=c and execute that C. If I tried doing the disable fork in the task A it does not proceed to task B and kill everything.So i want to use disable fork so that it should not go to task A and satisfy that condition. I am using +UVM_TIMEOUT as I have multiple wait statements.
Thanks.
You are still missing too much code to help. What calls task A and B.
I am calling the task in the run phase inside the driver class in the forever loop.
// clk generation
b<=1'b1;
c<=1'b1;
task driver::run_phase(...);
forever begin
seq_item_port.get_next_item();
send_to_dut();
seq_item_port.item_done();
task send_to_dut();
case(condition)
A: begin
A;
B: begin
B;
endcase
join_none
task A;
B;
C;
D;
join_any
task B;
C1;
D;
E;
join_any
I am calling in the drivers run_phase inside the forever loop. Here in the top I am driving b=1’b1 so wait statement is satisfied and it will go to task B. Then i am driving c=1’b1 so it is expected that as it is task B it will make task B’s condition=c and call the task C1 and not the task A’s condition=c and execute that C. If I tried doing the disable fork in the task A it does not proceed to task B and kill everything.So i want to use disable fork so that it should not go to task A and satisfy that condition. I am using +UVM_TIMEOUT as I have multiple wait statements.Please let me know.
Thanks.
