@(negedge a) begin
fork
begin //1
fork
wait(!b); //Consider this wont happen
$display("b is low");
#5ns; //Consider timeout happens
$display("b timeout");
join_any
disable_fork;
begin //2
fork
wait(!c); //Consider this wont happen
$display("c is low");
#10ns; //Consider timeout happens
$display("c timeout");
join_any
disable_fork;
begin //3
fork
wait(!d); //Consider this wont happen
$display("d is low");
$display("d timeout");
join_any
disable_fork;
join //If I change this to join_any, how does it make a difference?
In reply to abhi9891:
It makes a difference to the statement that executes immediately after this code fragment. It starts at 10ns with a join, and 5ns with join_any.
I was seeing a problem with fork join. Only statements b timeout and d timeout were executed and not c timeout (one with 10ns). Consider that there are no more statements after this code fragment.
I was thinking, if there was any specific reason. Does the disable fork, disable the main fork join as well and come out, hence not displaying the c(10ns) timeout?
I have then tried with fork join_any and all timeout are printing.
Considering no more code fragments after this, join and join_any should give the same results in this case.
Tested your code one EDA, no problem: Edit code - EDA Playground
It might simply that your program has ended before c timeouts.
-An
