I have a piece of code like the one below:
initial
if(testname !== "test_1")
begin : block1
$display("TRIAL1 at line = %0d instance = %m",`__LINE__);
forever
@(posedge flag2);
$assertkill(0, top_tb.tb_file1.sb_if.ap_1);
`uvm_info("",$sformatf("TRIAL1 Entered at line = %0d Testcase name = %s at time = %t instance = %m",`__LINE__,testname,$realtime),UVM_LOW)
if(stop)
$display("TRIAL1 block1 disabled at time = %t",$realtime);
disable block1;
join_none
end : block1
begin : block2
$display("TRIAL2 at line = %0d instance = %m",`__LINE__);
forever
@(negedge flag2);
$asserton(0,top_tb.tb_file1.sb_if.ap_1);
`uvm_info("",$sformatf("TRIAL2 Entered at line = %0d Testcase name = %s at time = %t instance = %m",`__LINE__,testname,$realtime),UVM_LOW)
if(stop)
$display("TRIAL2 block2 disabled at time = %t",$realtime);
disable block2;
join_none
end : block2
Question: I’m seeing that TRIAL1 and TRIAL2 statements are getting printed. For the simulation that i’m running any one of the two @(posedge flag2) or @(negedge flag2) would definitely get executed. With this i should be able to see the uvm_info print statement on my log. But i'm not seeing the print statement at all from the uvm_info. I’m also not seeing this print statement : $display(“TRIAL2 block2 disabled at time = %t”,$realtime); and $display(“TRIAL2 block2 disabled at time = %t”,$realtime);.
I’m just not understanding why the `uvm_info statements are not getting printed.
I appreciate any insights you can provide.
Regards,
Ritvik
