Hi All,
I have a port of an interface, which I would like to force to a value for all instances of interface.
Do we have an efficient way to implement this, rather than adding force for each interface’s instance.
Thanks in Advance
Hi All,
Thanks in Advance
In reply to g8gretchen588:
You can use the bind construct to insert any kind of behavior into all instance of a particualt interface or module.
interface my_interface;
wire my_signal;
always_comb $display("%m my_signal is %b @%0d", my_signal, $realtime);
endinterface
module hdl_top;
my_interface i1();
my_interface i2();
my_interface i3();
// DUT might go here
interface my_force(ref event trig,
input wire value);
initial @trig force my_interface.my_signal = value;
endinterface
module tb_top;
event trigger;
logic data;
// note that tb_top. is required in the port connections because the instance
// is from the perspecive of the binding location.
bind my_interface my_force bind_inst (tb_top.trigger,tb_top.data);
data = 1;
#10 ->trigger;
#10 data = 0;
#10;
This is a very simple triggering mechanism; there are more elegant ways of doing this if you have a class based testbench
This is exactly what I was looking for. Thanks Dave.
