I wanted to do functional fault testing on a small circuit, like this:
module logic2(
input wire a,
input wire b,
input wire c,
input wire e,
output wire y,
output wire z
wire d, f, g, h, j, k, w, x, p, q;
assign f = d;
or gate1(d, a, b);
and gate2(p, d, e);
not gate3(g, p);
or gate4(j, g, h);
nand gate5(w, b, j);
and gate6(x, j ,g);
not gate7(q, f);
nor gate8(k, q, c);
// final outputs
and gate9(z, w, x);
or gate10(y, k, a);
I was using force-release on the wires for the submodule in the top module, but it just gives the correct output and doesn’t force the wires. I tried not passing sel to top, and just assigning it values inside the top module itself, but it still doesn’t seem to work.
I have been looking through the forums a lot and haven’t been able to find the problem. I am using iverilog for this. Here is the top module and testbench if that helps:
module top(
input wire [4:0] sel,
input wire control,
input wire a,
input wire b,
input wire c,
input wire e,
output wire y,
output wire z
logic2 circ(a, b, c, e, y, z);
if(sel==5'b00000) begin
// do not force
if(sel==5'b00001) begin
force circ.a = control;
if(sel==5'b00010) begin
force circ.b = control;
if(sel==5'b01010) begin
force circ.k = control;
module testbench;
reg in1, in2, in3, in4;
wire o1, o2;
wire v1, v2;
reg [3:0] testval;
reg [4:0] sel;
reg control;
integer i, stuck, node;
integer scan1;
integer tb_file1;
top circ_fault(sel, 1'b0, in1, in2, in3, in4, o1, o2);
logic2 circ_verify( in1, in2, in3, in4, v1, v2);
$dumpfile("logic2_tb.vcd");
$dumpvars;
tb_file1=$fopen("testcases_exhaustive.txt", "r");
for(i=0; i<16; i=i+1) begin
scan1 = $fscanf(tb_file1, "%b\n", testval);
$display("\nTestcase: %d %b", i+1, testval);
in1 = testval[3];
in2 = testval[2];
in3 = testval[1];
in4 = testval[0];
$display("Expected: %d%d", v1, v2);
for(node=1; node<=16; node=node+1) begin
sel = node;
for(stuck=0; stuck<=1; stuck=stuck+1) begin
if(stuck==0) begin
control = 1'b0;
if(stuck==1) begin
control = 1'b1;
if( (o1!=v1)||(o2!=v2) ) begin
$display("node:%d, sa%d ", node, stuck);
//$display("o1o2 %d%d v1v2 %d%d", o1, o2, v1, v2);
$finish;
