For loop running infinitely
I ran the below code and it keeps on running. can anyone explain this? why does it keep on running?
    for(bit [1:0]i=0;i<4;i++)
      $display("Loop is executed");
In reply to Arvind Tiwari:
You are using the two-bit variable ā€˜i’ as the loop variable. A two-bit variable can have the values 0,1,2 and 3, and will loop from 3 to 0 when incremented. The maximum value of 3 is less than 4, so the loop termination condition is never met, so the loop is infinite.
