Hi guys,
I have a legacy testbench using system verilog, and there is a requirment to supress some error info when simulate.
Does anyone know the common practice to do that?
Hi guys,
In reply to philerpeng:
Hi guys,
How are you displaying the error messages?
If by “legacy testbench” you mean something that was not UVM based, you can still convert the messages to use the UVM reporting API by changing the $display(“message”) to `uvm_error(“uniqueid”,“message”). Then you can control the messages from the command line with +uvm_set_action from the command line, or within your code.
Thanks for sugesstions.
I am a SV and UVM practicer, not familiar with OVM.
Let me give a description of test env and my requirement.
The tesbench is a pure system verilog tb, but it has a register model(somewhat like UVM register model), the model is writen like:
typedef struct packed{
bit cmd_reg_read_0;
bit[8:0] cmd_reg_9_1;
bit cmd_reg_cmd_read_status_10;
bit[1:0] cmd_reg_31_30;
} reg_cmd_reg_t;
class reg_cmd_reg extends ovm_register #(reg_cmd_reg_t);
function new(string name, ovm_named_object p);
super.new(name,p);
WMASK='h20001401;
RMASK='hFFFFFFFF;
W1CLRMASK='h0;
W0SETMASK ='h0;
CLRONREAD='h0;
SETONREADMASK='h0;
class dev_reg_file extends ovm_register_file;
reg_cmd_reg r_cmd_reg;
super.new(name, p);
r_cmd_reg = new("cmd_reg",this);
add_register(r_cmd_reg.get_fullname(),'h010,r_cmd_reg);
there is a task like reg_wr(addr,data) is used to configure register.
my questions are:
the ERROR just like:
OVM_ERROR @1474731 ns: reporter [ovm_register_container] lookup register by address(): Offset/Address 0xffc has not been mapped.
The OVM did not have a register model. There were a number of proposals, and the one you show did not make it into the UVM standard. Even though all the class names are prefixed with ovm_*, they are imported as a separate package.
The OVM reporting system was migrated to the UVM, so you can use the same ovm_top.set_id_action() method to suppress the error. But are you looking to fix the error rather than suppress it?
