IMPORTANT NOTICE: Please be advised that the Verification Academy Forums will be offline for scheduled maintenance on Sunday, March 29th at 5:00 AM US/Pacific.
From Above queues, there is term called “SK” in different indexes of each Queue.
I need a logic such that, to get the common index of all Queues which has “SK”
From the above table, “SK” is in common index[Index =3] for all Queues .Logic should return the common indexes.
You already had that answer. I followed two different approaches to get results for two different requirements.
module dynamic_array;
//dynamic array declaration
string qa[$];
string qb[$];
int qc[$];
int qd[$];
int count_indexx[string]='{default:0};
int result1[$];
string result2[$];
initial
$display("Queue Allocation");
qa= {"AB","SK","OU","SK","OU"};
qb = {"EP","AB","EP","SK","EP"};
qc={23,48,45,61,99};
qd={45,21,35,23,27,83,99};
$display("------qa---------");
foreach(qa[i]) $display("\t qa[%0d] = %s",i, qa[i]);
$display("-----qc--------");
foreach(qc[i]) $display("\t qc[%0d] = %0d",i, qc[i]);
if (qa==qb) $display("Good");
else $display("BAD");
$display("\n");
qa=qa.unique();
qb=qb.unique;
qc=qc.unique; // If we follow 1st method we don't need to make these queues unique.
qd=qd.unique; // If we follow 1st method we don't need to make these queues unique.
// 1st method
result1 = qc.find() with (item inside{qd});
$display("%0p",result1);
// 2nd method
foreach(qa[xx]) count_indexx[qa[xx]]++;
foreach(qb[xx]) count_indexx[qb[xx]]++;
result2 = count_indexx.find_index() with (item>=2);
$display("%0p",result2);
