i am not getting this code can any one solve this
module tb;
reg[3:0] a,b;
wire[4:0] c;
and_4bit dut(.a(a),.b(b),.c(c));
integer test_file;
test_file = $fopen("test_data.txt","r");
if(test_file == 0) begin
$fatal("\n error : could not open test_data.txt");
integer line_num = 0;
integer errors = 0;
while(!$feof(test_file))begin
line_num++;
$fscanf(test_file, "%b,%b,%b" ,a,b,c);
#1;
if(c !== a&b) begin
$display("\n error in line %d : expected c=%b, but got c=%b",line_num,a&b,c);
errors++;
if(errors == 0)begin
$display("\n all tests passed!");
else begin
$display("\n %d errors found in %d tests",errors,line_num);
$fclose(test_file);
$fopen("test_data.txt", "w");
$fopen("test_data.txt", "0000,0000,00000");
$fopen("test_data.txt", "0001,0001,00001");
$fopen("test_data.txt", "1100,0011,00000");
$fopen("test_data.txt", "1010,0101,00000");
$fclose("test_data.txt");
