This is an updated model
http://systemverilog.us/vf/unique_entry.sv
I corrected the push/pop, the maintenance of number of unique entries in the associative array, and the assertion itself.
// I have a synchronous FIFO. The depth of the FIFO is 32.
// Everytime the FIFO has 7 or any "n" unique elements inside it,
// "unique" signal goes HIGH. How do I test the "unique" signal going high
// in SystemVerilog or UVM? How would my scoreboard look like?
module top;
bit clk, pop, push;
int data=8, q1_size, q_num, just_popped;
int aa[int]; // associative array
int q1[$]; // queue, emulating the fifo
int num_unique=0;
always @(posedge clk) begin
automatic int temp_pop;
if(push) begin : push1 // if(push && !pop) begin : push_no_pop
if(!aa.exists(data)) begin : is_unique
aa[data]=1; // flag data into associative array
num_unique <= num_unique+1'b1; // incremnet number of uniques
q1.push_front(data); // maintain the queue
end : is_unique
else begin : is_not_unique // but is in the queue
aa[data]+=1'b1; // keep track of count
// num_unique <= num_unique+1'b1; // incremnet number of uniques
end : is_not_unique
end : push1
if(pop && q1.size != 0) begin : pop_q // if(pop && !push && q1.size != 0)
temp_pop=q1.pop_back(); // maintain the queue
aa[temp_pop]-=1'b1; // keep track of count
just_popped <= temp_pop;
if(aa[temp_pop]==0) begin : flushed
num_unique <= num_unique - 1'b1; // decrement uniques
aa.delete(temp_pop); // delete the associative array entry
end : flushed
end : pop_q
a_unique: assert(num_unique <= 7);
always_comb begin
q1_size=q1.size; // for debug
q_num=aa.num;
initial forever #10 clk=!clk;
repeat(5) push <= 1'b1;
repeat(200) begin
@(posedge clk); #2;
if (!randomize(push, pop, data) with
{ push dist {1'b1:=1, 1'b0:=2};
pop dist {1'b1:=1, 1'b0:=8};
data dist {[1:12]:=1, [0:0]:=3};
$stop;
For training, consulting, services: contact http://cvcblr.com/home
