Field mirror value is not updated with predictor
I was wondering if anyone else encounter the situation were the register model mirror value isn’t updating when using uvm_predictor?
MY code:
   //predictor declaration
   uvm_reg_predictor#(svt_axi_transaction)   predictor;
  //build phase
   predictor= uvm_reg_predictor#(svt_axi_transaction)::type_id::create("predictor", this);
   //connect phase
   predictor.map = cfg.reg_model.fpga_top.default_map;
   predictor.adapter= adapter;
   axi_system_env.master[0].monitor.item_observed_port.connect(predictor.bus_in);
Regards
Eran Rashkes
