- Fatal: (vsim-7019) Can’t locate a C/C++ compiler for ‘DPI Export Compilation’. iam getting this error while running uvm code can u adress how to resolve this issue?
In reply to nagendrareddy s:
Looks like you want to compile c/C++ code with an C/C++ compiler in your installation path.
See what verror 7019 is issuing:
vsim-vlog Message # 7019:
In order to use QuestaSim’s SystemVerilog DPI, a C compiler must be
visible at runtime. You can use the CppPath variable in the
modelsim.ini file to designate a compiler, or you can download
and install a built-in GCC from the Model Technology website.
BTW this is a tool-related issue.
[i]In reply to chr_sue:
sir can u explain how to add c/c++ compiler to my questasim tool step by step.Because i am a fresher plz
thank you
This forum is not for tool related issues. Please contact your vendor support team for additional assistance.
