Dear all,
I am confused with the following error: Fatal: (SIGSEGV) Bad handle or reference.
This error directs me to the line where I define the coverpoint.
covergroup reset_coverage (ref reset_seq_item item);
rst_cp: coverpoint item.rstn { // error seems to be here
option.at_least = 3;
bins low = {0};
bins high = {1};
bins others = default;
endgroup : reset_coverage
Any help will be appreciated.
Thank you.
Best regards,
vkantamn
dave_59
February 16, 2015, 9:50pm
2
This looks like a run time error - there should be more information in the error message, like a call stack trace. Most likely you failed to construct the covergroup before calling sample().
In reply to dave_59 :
Hello Dave,
the stack trace says:
HDL call sequence:
stopped at ./some_path/RESET_IF_coverage.svh 31 Function sample
This is exactly where I defined the coverpoint. Coming to the contructor of the covergroup, I see, I did it in the coverage class.
class coverage extends uvm_subscriber #(item);
uvm_component_utils macro
item item_inst;
reset_coverage cov_group;
function new (string name, uvm_component p);
super.new(name, p);
item_inst = new();
cov_group = new(item_inst);
function void write (input item t);
item_inst = t;
cov_group.sample();
Any suggestions please?
dave_59
February 17, 2015, 4:45pm
4
In reply to vkantamn :
There should be more information that that one line of error message you showed. There is normally information about the process that the segfault was executing on.
If you can runt interactively, use the tb command after the simulation halts.
Dave,
thank you very much for your follow-up and inevitable support. I sincerely appreciate this. I am adding entire log for your reference.
UVM_INFO verilog_src/questa_uvm_pkg-1.2/src/questa_uvm_pkg.sv(217) @ 0: reporter [Questa UVM] questa_uvm::init(+struct)
** Warning: NUMERIC_STD.“=”: metavalue detected, returning FALSE
Time: 0 ns Iteration: 0 Instance: /filter_verify_top/DUT_wrapper/filter_seqeuencer_dut_e_i
UVM_INFO @ 0: reporter [RNTST] Running test test_filter_001…
Time: 0 ns Iteration: 1 Instance: /filter_verify_top/DUT_wrapper/filter_seqeuencer_dut_e_i
UVM_WARNING ./FILTER_VERIFY_tb/sv/filter_verify_sb/sv//filter_verify_sb_env.svh(49) @ 0: uvm_test_top.tb_env.sb [CFG] Configuration object not initialized from outside. Generating one internally
UVM_INFO ./FILTER_VERIFY_tb/sv/filter_verify_tests/sv//filter_test_001.svh(27) @ 0: uvm_test_top.tb_env.virtual_sequencer@@filter_001_seq . [filter_001_seq] GP_FILT_VAL_I SET
UVM_INFO ./FILTER_VERIFY_tb/sv/filt_sequencer_IF/sv//FILT_SEQUENCER_IF_seq_lib.svh(147) @ 0: uvm_test_top.tb_env.filt_sequencer_IF_inst_env.agent.sequencer@@filter_001_seq..f_sequence_001 [FILT_SEQUENCER_IF_001_seq] Starting to generate traffic …
UVM_INFO ./FILTER_VERIFY_tb/sv/filt_sequencer_IF/sv//FILT_SEQUENCER_IF_driver.svh(104) @ 0: uvm_test_top.tb_env.filt_sequencer_IF_inst_env.agent.driver [ITEM]
Name Type Size Value
s_item FILT_SEQUENCER_IF_seq_item - @1260
gp_chan_1_i integral 4 'ha
gp_chan_2_i integral 4 'hf
gp_chan_3_i integral 4 'h0
gp_chan_4_i integral 4 'h0
gp_chan_5_i integral 4 'hc
gp_filt_val_i integral 10 'hcd
rd_filt integral 1 'h0
begin_time time 64 0
depth int 32 'd3
parent sequence (name) string 14 f_sequence_001
parent sequence (full name) string 68 uvm_test_top.tb_env.virtual_sequencer.filter_001_seq..f_sequence_001
sequencer string 62 uvm_test_top.tb_env.filt_sequencer_IF_inst_env.agent.sequencer
UVM_INFO ./FILTER_VERIFY_tb/sv/filt_sequencer_IF/sv//FILT_SEQUENCER_IF_seq_lib.svh(155) @ 10: uvm_test_top.tb_env.filt_sequencer_IF_inst_env.agent.sequencer@@filter_001_seq..f_sequence_001 [FILT_SEQUENCER_IF_001_seq] Traffic sequences have completed.
UVM_INFO ./FILTER_VERIFY_tb/sv/filter_verify_tests/sv//filter_test_001.svh(37) @ 1010: uvm_test_top.tb_env.virtual_sequencer@@filter_001_seq . [filter_001_seq] RESET SET INACTIVE
UVM_INFO ./FILTER_VERIFY_tb/sv/filter_verify_tests/sv//filter_test_001.svh(50) @ 1010: uvm_test_top.tb_env.virtual_sequencer@@filter_001_seq . [filter_001_seq] RD_FILT RAISED HIGH
UVM_INFO ./FILTER_VERIFY_tb/sv/reset_IF/sv//RESET_IF_seq_lib.svh(121) @ 1010: uvm_test_top.tb_env.reset_IF_inst_env.agent.sequencer@@filter_001_seq..r_sequence_001 [RESET_IF_001_seq] Starting to generate traffic …
UVM_INFO ./FILTER_VERIFY_tb/sv/filt_sequencer_IF/sv//FILT_SEQUENCER_IF_seq_lib.svh(147) @ 1010: uvm_test_top.tb_env.filt_sequencer_IF_inst_env.agent.sequencer@@filter_001_seq..f_sequence_001 [FILT_SEQUENCER_IF_001_seq] Starting to generate traffic …
UVM_INFO ./FILTER_VERIFY_tb/sv/filt_sequencer_IF/sv//FILT_SEQUENCER_IF_driver.svh(104) @ 1010: uvm_test_top.tb_env.filt_sequencer_IF_inst_env.agent.driver [ITEM]
s_item FILT_SEQUENCER_IF_seq_item - @1758
gp_chan_1_i integral 4 'hb
gp_chan_2_i integral 4 'hd
gp_chan_3_i integral 4 'h9
gp_chan_4_i integral 4 'h5
gp_chan_5_i integral 4 'h6
gp_filt_val_i integral 10 'h96
rd_filt integral 1 'h1
begin_time time 64 1010
depth int 32 'd3
** Fatal: (SIGSEGV) Bad handle or reference.
Time: 1030 ns Iteration: 1 Process: /RESET_IF_pkg::RESET_IF_driver::run_phase/fork #74_f61cbb6 File: ./FILTER_VERIFY_tb/sv/reset_IF/sv//RESET_IF_coverage.svh
Fatal error in Function sample at ./FILTER_VERIFY_tb/sv/reset_IF/sv//RESET_IF_coverage.svh line 31
HDL call sequence:
Stopped at ./FILTER_VERIFY_tb/sv/reset_IF/sv//RESET_IF_coverage.svh 31 Function sample
called from ./FILTER_VERIFY_tb/sv/reset_IF/sv//RESET_IF_coverage.svh 61 Function RESET_IF_pkg/RESET_IF_coverage::write
called from /opt/questasim_10.1c/questasim/linux/../verilog_src/uvm-1.1b/src/tlm1/uvm_analysis_port.svh 114 Function uvm_pkg/uvm_analysis_imp::write
called from /opt/questasim_10.1c/questasim/linux/../verilog_src/uvm-1.1b/src/tlm1/uvm_analysis_port.svh 76 Function uvm_pkg/uvm_analysis_port::write
called from ./FILTER_VERIFY_tb/sv/reset_IF/sv//RESET_IF_driver.svh 94 Task RESET_IF_pkg/RESET_IF_driver::get_and_drive
called from ./FILTER_VERIFY_tb/sv/reset_IF/sv//RESET_IF_driver.svh 74 Task RESET_IF_pkg/RESET_IF_driver::run_phase
Fatal error reported during simulation. Cannot run ‘fcover’ command. Please look above output for the fatal error message(s).
The error pops up only when the following line of the code is uncommented: cov_group.sample();
The error closely points to driver where the drive task is defined:
task drive(REQ req, RSP rsp);
`uvm_info("DEBUG", {"\n", req.sprint()}, UVM_FULL);
`uvm_info("ITEM", {"\n", req.sprint()}, UVM_NONE);
// set signals according to 'req'
// capture any output (including input) in 'rsp'
@(posedge vif.clk_i);
vif.rstn = req.rstn;
endtask: drive
I dont have good understand about req and rsp. Maybe something wrong with driving the signals?
Thank you and Regards,
dave_59
February 18, 2015, 3:26pm
6
That stack trace starts where it says
HDL call sequence
You need to look at line 94 of
There is probably a call to ap.write(t) and t is null. This may get very complicated to debug in a forum, I suggest you learn how to interactively debug your code and trace the execution of your code. Try to find someone locally to help you.
BTW, there is no need for the line in your class coverage’s constructor
item_inst = new();
item_inst will be overwritten with another object what write() gets called.
