Fatal_error in Driver Run_phase
// ** Fatal: (SIGSEGV) Bad handle or reference.
Time: 0 ns Iteration: 49 Process: /uvm_pkg::uvm_task_phase::execute/fork#137(#ublk#215181159#137)_7fefec2e37d File: /cadtools/mentor/Questa_10.6b/questasim/linux_x86_64/../verilog_src/uvm-1.1d/src/base/uvm_common_phases.svh
Fatal error in Task or_top_sv_unit/or_driver::run_phase at ../sv//or_driver.sv line 52
`ifndef or_driver
`define or_driver
import uvm_pkg::*;
`include"uvm_macros.svh"
`include"or_transaction.sv"
`include"or_if.sv"
`include"or_config.sv"
class or_driver extends uvm_driver#(or_transaction);
  `uvm_component_utils(or_driver)
  virtual or_if.DRV vif;
  or_transaction  data_sent;
  or_config cfg;
    extern function new(string name="or_driver",uvm_component parent);
    extern function void build_phase(uvm_phase phase);
    extern function void connect_phase(uvm_phase phase);
    extern task run_phase(uvm_phase phase);
 //===========NEW CONSTRUCT=======//
    function or_driver::new(string name="or_driver", uvm_component parent);
      super.new(name,parent);
 //==========BUILD PHASE=======//
 function void or_driver::build_phase(uvm_phase phase);
   super.build_phase(phase);
   if(!uvm_config_db#(or_config)::get(this,"","or_config",cfg))
     `uvm_fatal("or_driver_FATAL_ERROR","config can`t get have you set it ?????")
//==========CONNECT PHASE=========//
function void or_driver::connect_phase(uvm_phase phase);
  vif = cfg.vif;
//=============RUN PHASE===========//
   task or_driver ::run_phase(uvm_phase phase);
     forever
            vif.a <= data_sent.a;    // line no 52
            vif.b <= data_sent.b;
   `endif
//====================Environment code //==================
`ifndef or_env
`define or_env
import uvm_pkg::*;
`include"or_agent.sv"
`include"or_scb.sv"
`include"env_config.sv"
class or_env extends uvm_env;
`uvm_component_utils(or_env)
or_agent agt;
or_scb scb;
or_config cfg;
env_config ecfg;
extern function new(string name="or_env",  uvm_component parent);
function or_env::new(string name="or_env",  uvm_component parent);
function void or_env::build_phase(uvm_phase phase);
if(!uvm_config_db#(env_config)::get(this    ,  ""  , "env_config" , ecfg))
`uvm_fatal("FATA_ERROR_ENVIRONMENT"  ,  "cant get env config have you set it??")
cfg = ecfg.cfg;
if(ecfg.or_agent)
       uvm_config_db#(or_config)::set(this   , "*"  ,  "or_config" , cfg);
        agt = or_agent::type_id::create("agt" , this);
//=======================SCOREBOARD=====================//
if(ecfg.or_scb)
scb = or_scb::type_id::create("scb"  , this);
//==========================connect phase======================//
function void or_env::connect_phase(uvm_phase phase);
if(ecfg.or_scb)
       agt.mon.monport.connect(scb.fifo.analysis_export);
`endif
//=============================test_code ==========================//
`ifndef or_test
`define or_test
import uvm_pkg::*;
`include"or_env.sv"
`include"or_sequence.sv"
class or_test extends uvm_test;
`uvm_component_utils(or_test)
or_env envh;
or_config cfg;
env_config ecfg;
extern function new(string name="or_test",uvm_component parent);
extern function void or_configure();
extern function void end_of_elaboration_phase(uvm_phase phase);
function or_test::new(string name="or_test",uvm_component parent);
function void or_test::or_configure();
//===================WRITE PART================//
if(ecfg.or_agent==1)
      cfg=or_config::type_id::create("cfg");
     if(!uvm_config_db#(virtual or_if)::get(this,"","vif",cfg.vif))
     `uvm_error(get_type_name(),"can't get have you set it????")
     if (ecfg.active)
         cfg.is_active=UVM_ACTIVE;
         cfg.is_active=UVM_PASSIVE;
//================BUILD_PHASE====================//
function void or_test:: build_phase(uvm_phase phase);
ecfg=env_config::type_id::create("ecfg");
or_configure();
ecfg.cfg = cfg;
//cfg = ecfg.cfg;
uvm_config_db#(env_config)::set(this,"*","env_config",ecfg);
envh= or_env::type_id::create("envh" , this);
//=====================end of elaboration phase==============//
function void or_test::end_of_elaboration_phase(uvm_phase phase);
super.end_of_elaboration_phase(phase);
uvm_top.print_topology();
//============================TEST1=======================================//
class or_test1 extends or_test;
`uvm_component_utils(or_test1)
or_sequence1 or_seq1;
extern function new(string name="or_test1",uvm_component parent);
function or_test1::new(string name="or_test1",uvm_component parent);
function void or_test1::build_phase(uvm_phase phase);
//=================RUN_PHAS===========================//
task or_test1::run_phase(uvm_phase phase);
phase.raise_objection(this);
or_seq1 = or_sequence1::type_id::create("or_seq1");
or_seq1.start(envh.agt.sqr);
phase.drop_objection(this);
`endif
//=======================Top module ====================//
`ifndef or_top
`define or_top
import uvm_pkg::*;
`include"or_test.sv"
`include"or_if.sv"
`include"or_gate.v"
module or_top();
or_if inf();
// DUT instansiate =====================//
or_gate DUT ( .a(inf.a)  ,  .b(inf.b) ,  .y(inf.y)     );
initial
   uvm_config_db#(virtual or_if)::set(null,"*", "vif", inf);
   run_test("or_test1");
`endif
In reply to raj@123:
The error message is pointing to your problem. You do not have a seq_item object in your run_phase.
This task should look like this:
     forever begin
            seq_item_port.get_next_item(data_sent);
            seq_item_port.item_done();
With get_next_item you are retrieving a seq_item obkect from the sequencer.
