Fatal Error bad reference
Hi All,
I got this Fatal error while running a sim :
** Fatal: (SIGSEGV) Bad handle or reference.
Fatal error in Module spi_if at ///***/spi_if.sv line 651
I saw line 651 of the SPI interface i see this code :
always @(SCK)
   if (curr_mode) begin
      MinData = spi_cfg.Mindr * DELAY_UNIT * 1ps;
   else begin
#651      MinData = spi_cfg.Minsr * DELAY_UNIT * 1ps;
spi_cfg is handle of class spi_agent_config
spi_agent_config   spi_cfg;
The variable Minsr is defined as int in the class spi_agent_config
Not sure what to debug in this case, any pointers
Tejas
In reply to tejasakulu:
spi_cfg is not a class handle, it is a class variable that should hold a handle to a spi_agent_config object. Make sure you have assigned it and is not currently null.
Hi Dave :
Sorry i did not get that can you elaborate please
Tejas
See A Short Class on SystemVerilog Classes - Verification Horizons
Have you constructed or assigned a handle to spi_cfg?
Add this line before line #651
if (spi_cfg == null) $fatal(1, "I was lazy and did not construct an object before trying to reference it");
