Fail to cast of enum
In reply to Ep1c F4iL:
You cannot assign an enum variable with an integer without an explicit cast. $urandom_range returns an integer, and the result of randomize is a true or false bit indicating if the constraints could be met.
You probably want
const opcode_t opcode = LOAD;
vif.opcode = opcode.next($urandom_range(16));
A simpler solution would be
opcode_t opcode;
void'(randomize(opcode));
vif.opcode <= opcode;
