Extending from a parameterized uvm class
I have a parameterized base class which extends from uvm_component:
class bc_port_sb#(type T = uvm_sequence_item) extends uvm_component;
  `uvm_component_param_utils(bc_port_sb#(T))
I want to extend from this class with a different parameter:
class my_port_sb extends bc_port_sb#(my_pkt);
  `uvm_component_utils(my_port_sb)
I have instantiated this class in my env:
class my_env extends uvm_env;
  my_port_sb  scoreboard;
  scoreboard = my_port_sb::type_id::create("scoreboard", this);
I have also overriden the type of transaction in my base test:
class my_base_test extends uvm_test;
  super.build_phase(phase);
  set_type_override_by_type(my_pkt::get_type(),uvm_sequence_item::get_type());
But I am still getting a compile error WRT the type of transaction:
Error-[ICTTFC] Incompatible complex type usage
Incompatible complex type usage in task or function call.
class TESTBENCH.my_env_pkg::bc_port_sb#(class my_env_pkg::my_pkt)', while the type of the formal is ‘class TESTBENCH.my_env_pkg::bc_port_sb#(class uvm_pkg::uvm_sequence_item)’
Can you please suggest as to what am I missing here?
In reply to sid02101990:
You are overriding the wrong class. It is not your seq_item you have to override. It is the scoreboard class which is parameterized. You have to override this one.
Hi chr_sue,
Thanks for the reply.
By override the scoreboard class, do you mean:
set_type_override_by_type(bc_port_sb#(my_pkt)::get_type(),bc_port_sb#(uvm_sequence_item)::get_type());
I did this and got the same error.
You have to consiuder the actual parameter for your class in the construction and the override.
