Execution of function after it unblocks
Hi Forum,
Consider the following Tb
 // Assume 'write_beat' class is defined as
 class write_beat;
   bit [3:0] id;
   byte unsigned data[];
   // Other properties and APIs
 //  Within 'env' component ::
 // (1) Declare the class :: `uvm_analysis_imp_decl(_wdata)
 // (2) Declare handle of (1)
 //     uvm_analysis_imp_wdata#(write_beat,env) wr_beat_imp;
 //     semaphore                               s1;
 // (3) Within constructor of 'env' ::
 //     wr_beat_imp = new("wr_beat_imp",this);
 //            s1   = new(0);
 // (4) TLM Connection to Monitor in connect_phase() ::
 //     axi_slv.agent.monitor.wr_beat_port.connect(wr_beat_imp);
 // (5) Defining the write* function in 'env' ::
 function automatic void write_wdata(write_beat tr);
   $display("Input transaction has id: %0d",tr.id);
       s1.get(1);
       $display("Post s1.get(1), input transaction has id: %0d",tr.id);
       // Additional logic here
   join_none
 endfunction:write_wdata
 // Assume that s1.put(1) is done in a separate write_* function
Assume that the AXI slave monitor calls ap.write(txn) thrice before the 1st s1.put(1) executes.
Hence function ‘write_wdata’ would be called thrice and all 3 calls would be blocked via s1.get(1)
(Q1) Monitor creates a new object ( i.e calls new() ) every time it broadcasts an AXI pkt, how is it that write function is still able to see the properties associated with previous broadcast ?.
In other words, in the monitor upon creation of a new object the previous object would cease to exist yet how is that upon getting a key, we are able to observe properties associated with previous objects
(Q2) If the monitor clones the object before calling ap.write(txn), would it make any difference ? ( assuming that user never alters the properties in respective write* functions )
Since write_wdata() has an automatic lifetime (and all class methods have automatic lifetimes, so there’s no need for the automatic keyword), each call to the function creates a new tr variable. The life of tr is extended because it’s referenced inside the fork/join_block. Therefore, if each invocation of write_wdata() is passed a unique handle to the txn object, the process blocked by the get() has access to that txn object.
You have a choice between calling new() or clone() before calling write() in the monitor. The choice depends on whether you need to preserve property values between transactions. Remember that clone() copies all properties.
