Event Synchronization Issue in SystemVerilog D Flip-Flop (DFF) Testbench
I am working on a SystemVerilog testbench for a D Flip-Flop (DFF) design, and I’m having trouble with event synchronization in the verification environment. The generator task generates 5 transactions and triggers the gen_done event when finished, but the environment reports that the generator is still running, even after the event is triggered.
task run();
    repeat (num_transactions) begin
        trans = new();
        assert(trans.randomize());
        trans.display("Generator");
        gen2drv.put(trans);
    $display("Generator: Finished generating %0d transactions.", num_transactions);
    // Debugging
    $display("Generator: Waiting to trigger gen_done...");
    -> gen_done;
    $display("Generator: gen_done event triggered...");
And in the environment:
task run();
        gen.run();
        drv.run();
        mon.run();
        scb.run();
    join
    if (gen_done.triggered) begin
        $display("Generator has finished.");
    end else begin
        $display("Generator is still running.");
if (drv_done.triggered) begin
    $display("Driver has finished.");
end else begin
    $display("Driver is still running.");
if (mon_done.triggered) begin
    $display("Monitor has finished.");
end else begin
    $display("Monitor is still running.");
if (scb_done.triggered) begin
    $display("Scoreboard has finished.");
end else begin
    $display("Scoreboard is still running.");
// Wait for all events to be triggered
wait (gen_done.triggered && drv_done.triggered && mon_done.triggered && scb_done.triggered);
$display("All tasks completed.");
output:
Checking if all tasks are completed…
You do not show enough code, but I am assuming that your gen.run() method finishes at a time before the others methods. The triggered method is only true in the time slot when the event is triggered–as soon as time advances, it goes back to zero.
But since you are using a fork/joint construct, I’m not sure why you even need the events because the join does not happen until after all the run methods have finished.
Thank you for your insights!
I expected the event to remain triggered until checked, but as you mentioned, it seems the event resets after the time slot advances.
I was using the events to explicitly track the completion of each component. Do you suggest removing the events entirely and relying solely on the fork/join behavior for synchronization? Or is there a better way to track task completion without running into this issue?
I’d appreciate any further guidance. Thanks again!
class environment;
  generator gen;
  driver drv;
  monitor mon;
  scoreboard scb;
  virtual dff_if vif;
  mailbox gen2drv;
  mailbox mon2scb;
  event gen_done;  // Signals that the generator has finished generating transactions
  event drv_done;  // Signals that the driver has finished driving transactions
  event mon_done;  // Signals that the monitor has finished monitoring transactions
  event scb_done;  // Signals that the scoreboard has finished comparing transactions
  function new(virtual dff_if vif, int num_transactions);
    this.vif = vif;
    gen2drv = new();
    mon2scb = new();
    gen = new(gen2drv, gen_done, num_transactions);
    drv = new(vif, gen2drv, drv_done, num_transactions);
    mon = new(vif, mon2scb, mon_done, num_transactions);
    scb = new(mon2scb, scb_done, num_transactions);
  task run();
      gen.run();
      drv.run();
      mon.run();
      scb.run();
    join
    $display("Checking if all tasks are completed...");
    // Generate report
    scb.report();
    $display("Functional Coverage: %0.2f%%", mon.trans.cg.get_coverage());
    // Terminate the simulation
    $display("Simulation finished.");
    $finish;
class generator;
  rand dff_transaction trans;
  mailbox gen2drv;
  event gen_done; // Event to signal when the generator is done
  int num_transactions; // Number of transactions to generate
  function new(mailbox gen2drv, event gen_done, int num_transactions);
    this.gen2drv = gen2drv;
    this.gen_done = gen_done;
    this.num_transactions = num_transactions;
  task run();
  $display("Generator: Starting to generate %0d transactions.", num_transactions);
    trans = new();
    gen2drv.put(trans);
  -> gen_done;
If all of your run methods have a definitive termination, then the simple fork join construct works. But in most testbenches the driver and monitor processes run indefinitely. So it’s only when some of the processes finish that you want to end the test. You can do that using a semaphore as described here.
The UVM has objection and barrier classes that help you out when to know the test is done.
Thank you for the guidance!
I’ll try it with a semaphore.
